Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Hi! my mixer is about over 10 years old , its making a sqeeking like kind a noise and its spains i think a bit to fast , could you tell me what do you think is the problem
    Problem Solver:
I had your same issue with the speeds. I think you need to adjust the speed through the speed control panel.
Open the back spherical cover on the Kitchenaid KSM90, the area with one screw on the top. You should see the speed control panel, a black and gold square connected to wires. There should be three large silver screws - two on the top, left and right - and one on the bottom. If you turn the top two screws clock wise the machine slows down at lower speeds. When you adjust the bottom screw, the higher speeds are effected. This process is called "tuning" and you can find an online video how-to through sites like Youtube.
As for the squeaking, you maybe replace some of the grease inside of the machine. Food grade gear lube would do if you are up for the challenge, but kitchenaid also sells a grease for their stand mixers for a pricey $20. It isn't hard to put in new grease and clean out the old but requires a lot of disassembly.
~ I am not an expert but a hobbyist. This advice is only my opinion based on limited experience. ~
Posted on Jul 30, 2011
All speeds work but all too fast
the mixing speed was attained by the use of a potentiometer ( variable resistor ) that would have controlled the power into the board or from the board to the motor
it would be under the speed setting knob
maybe the resistor in use is not the right one and is not reducing the voltage sufficiently to do the job
Nov 08, 2015 | KitchenAid K45SS Classic Stand Mixer
Makes Noise in all speed settings
From what you describe, it sound like the mixer has seen better days. It may be possible to take it apart and service it, but I think you are better off replaceing it with a new one.
May 01, 2014 | Rival Food Mixers
Kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid K5AWH Stand Mixer
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart A200 Commercial Mixer
Manufactured in 1931. Want to sell it? My girl just opened a restaurant and needs one... All the best.
Nov 20, 2008 | Food Mixers
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission case.is there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
Jan 03, 2008 | Magic Mill DLX 2000 Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
251 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
