Question about Xerox DocuColor 12 Color Copier
Instead of Bule print DC12 prints Violet - Xerox DocuColor 12 Color Copier
    Problem Solver:
  • 6 Answers
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
Posted on Jun 04, 2011
Dc12
Drum Sensore is dirty
Solution
put out first drum & see up side in near ibt belt one sensore (Small Steel Body ) Clear with Alcahol.
Jul 11, 2010 | Xerox DocuColor 12 Color Copier
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
How to do 2 sided printing in dc12
every driver is slightly different, but after selecting a job to print, click on either "printing preferences", or "printing properties", then look for a "layout" button, or "finishing", or similar, and you'll find it (assuming your machine has the "duplex" (double-sided) feature.
May 16, 2009 | Xerox DocuColor 12 Color Copier
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
My dc12 print a uniform dotted page
Looks like the printer drivers are 'up the pole'. Try re-installing the printer drivers and send a test page to check.
Hope this helps......
Oct 29, 2008 | Xerox DocuColor 12 Printer
My dc12 don't print good. They print as shadow
If there is a shaddow on the printed documents, then it may be you drum needs replaced in the printer...
Oct 28, 2008 | Xerox DocuColor 12 Printer
Xerox docu color 12
u check drum,ibt belt,2nt btr roller and fuser life... then do full service, then calibrate ur fiery also.. first u check developer bios plate.. if its have more dust print comes like that.. all the best..
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
327 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
