Question about Sharp Heating & Cooling
I just purchased a used sharp ac it looks like it is a older model but i cant get it to turn on at all, i was told that it works fine so im i doing something wrong i assumed that the on/off switch is how you turn it on? did i get ripped off ?
    Master:
  • 403 Answers
Most likely you got ripped off, did you have it run before you bought
Posted on May 26, 2011
Lc 37hv4 sharp tv
Unplug the TV from AC mains wall socket, switch the main power On, press and hold the Volume UP & Channel DN together and while pressing these to buttons, plug the AC cord into AC wall socket. This is the common procedure should be done to most models of Sharp TVs, to enter its service mode option. The procedure might be different to model to models. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Televison & Video
Compressor or control switch? So i have a 2002 nissian altima and the ac stopped worker, i took it to two different mechanic shops and got two different answers. i have no desire to take it to a third...
your friend should be able to check the switch with a multimeter to see if it is good it could also be your hot & cold dial and not the control panel but on some models you have to change the whole panel if the car is blowing hot air hotter than the outside temperature it could also be the door actuator in the dash that is not openning & closing correctly allowing the hot air from your heater core to mix with your cold air from your a/c
Aug 25, 2013 | Cars & Trucks
Sharp AY-A249J Split System Air Conditioner not working, the timer light flashes 5 times and the power light does not flash at all, the remote has limited function, it turns the indoor unit on and off and...
Thanks for your replies, I had a Sharp authorised tech look at it and im told it's the indoor circuit board. Im told its a $360 repair job all up, that sure beats replacing the entire ac or putting up with the heat...
Dec 07, 2012 | Sharp AF-S120FX Air Conditioner
I have an a31 i recently replaced the battery it works fine but when ever i put it for charging and disconnect it when it is done the battery meter says it is still connected so i cant get my real power...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 29, 2011 | IBM ThinkPad A31 Notebook
I have an HP G60 laptop that has been shutting down by itself lately. The battery is 2 years old and does not hold a charge for very long. It seems to occur usually when the unit is plugged in with the...
Hi there! Well for this kind of problem usually you have to look on two problems . First for the battery itself the expected life of that is only 1year it depends on your usage on it. Because all battery are consumable so maybe the battery is the issue here. But you need to look on the Ac adapter as well by checking on the Bios (when you turn on the Computer Press F2 that is the Bios section). Check the Ac adapter if it's being detected there. Or you can also take out the battery and run the computer with just an Ac adapter then check if that will work. If using the computer with just an ac adapter works fine. Buy a new battery. Hope this helps . God Bless.
Apr 20, 2011 | HP Computers & Internet
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
My garage door openers and wireless entry key pad do not work with the new door opener I just purchased. Sears (Springfield, Or) told me it is because of 'new' techonolgy. They also do not have the...
Hello Jon , I was an installer with sears for ten years installing theese machines, First of all since you did,nt buy the kit with the remote and bought that seperately the codes are most likely different and the keypad is really for a older model , the salespeople their are not very knowlegable when it comes to stuff like that , look at your owners manual in the back and their will be an accesorry page ,look at the keypad model # on that page and that will be the compatible one for your machine,your machine at the very cheapest comes with one remote ,spend a little more and get two remotes spend a little more and you get two remotes and a keypad , theese machines are built by LIFTMASTER/CHAMBERLAIN so you can also purchase a universal receiver kit ! Just remember it,s always good to let the salesman know your situation that you intended to use your old keypads and controls , im shure he would have saved you the time of purchasing that machine in the first place ! hope i was able to help you ,sincerely GLENN
Mar 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Luquid crystal television set - 125-240 AC
You have basically 2 options available to you:
1) Contact Sharp at the address you listed and they will instuct you on what you need.
2) Purchase a power conversion transformer. This will convert the 240AC to 110 AC and you can use the standard 110 AC cord.
Dan
Feb 13, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LC-32d40U Sharp Aquos Screen shows "please wait" controls do not respond
Hi.
Im not familiar with your TV set as it is made for USA but here in the UK some sharp models suffer with similar problem & this is the remedy.
As I said I cant gtee it will sort your problem but give it A try.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. This should hopefully clear the problem.
  3. http://dysonmanuals.llc.nu/
Apr 03, 2008 | Televison & Video
Heating & Cooling Logo
53 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
