Question about Roper FEP330KQ Electric Kitchen Range
Power substation blew up last night, which meant flickering lights, and low power (extremely weird). Today I have power -- finally -- but I can't reset my oven like I usually do when there is a power outage. It has the standard message "PF", but in addition, it also says "F1" and "E1", and it beeps for at least a minute every time I try to reset. Help!
  • 57 Answers
You have a defective touch pad(stuck button) probably from the surge that happened last night. to access this you will need to disconnect power and remove the back upper panel. Usually four screw hold on the board. Make sure when you are changing the board swap wire for wire to ensure correct install.
Part Number: 3191645
Posted on May 26, 2011
Testimonial: "Answered quickly and gave step by step instructions -- including safety steps. Thanks!"
  • mojo183 May 26, 2011
    I suspected as much -- thanks most of all for giving part number! I was worried about having to order without having a clear idea of what I needed to order.
Power steering
Have you inspected the belt? It is probably stretched or damaged...the belt turns the power steering unit, and charges your battery via the alternator...(low battery light) Did you drive through some deep water last night? Be sure to inspect this so you do not get stranded. Hope this helps.
Mar 24, 2014 | 2000 Oldsmobile Silhouette
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
PS2 Reset button stays Red and won't change.
try this:
go here and go to the very end
www.powerfulguides.com/ps2
no model # was given
hope this helps :D
Jul 31, 2009 | Sony PlayStation 2 (PS2) Console
Low beams don't work
sounds like you are having problems with the relay. I suggest tracing wires until you find the relay and replace it. If relay checks out ok, it may be the switch itself.
May 22, 2009 | 2005 Mercury Mariner
Sounds like a loose connection at the bulbs. Recheck them and try again. Also, I have seen bad bulbs from the parts store, so inspect the filaments on each to ensure they are good. Remember, dno't touch the glass!
May 22, 2009 | 2001 Dodge Durango
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Roper FEP330KQ Electric Kitchen Range Logo
181 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
