Where's the manual power button on the tv? - Televison & Video
  • 53 Answers
It could be anywhere fro the from bottom to the right side and top.
Posted on May 26, 2011
Testimonial: "Thanks"
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Sep 05, 2012 | Sharp Televison & Video
How do i programe my dish remote to my Sanyo tv and to my dish reciever
The Dish TV remote control allows you to program the TV, VCR and DVD codes so that all you need is one remote. Most TVs can be programmed into the remote using specific codes in the Dish TV remote manual. But if you don't have a manual or list of codes, you can program the remote manually.
Instructions 1. Using Programming Codes
Find the TV code for your TV in the list from the Platinum Remote Control User's Guide (See References). For example, if you have a Kenwood TV, the three possible codes to try are 506, 573 and 712.
Press the "TV" button on the remote. Hold down the button until the "Sat," "VCR" and "Aux" buttons light up. Release the "TV" button and it will be flashing.
Enter the first code using the keypad. If you want the remote to control all functions on the TV, enter the code and press the # key. The "TV" button will flash three times.
Press the power button to turn off the TV and turn it back on again. If the code was correct, the TV will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press and release the "Power" button on the remote.
Press the arrow up key and stop. If the TV doesn't turn off, press the arrow up key again. Continue pressing the arrow up key until the TV turns off. Do not go fast when moving through the codes or you could miss the correct code. Press the arrow key and wait at least 20 seconds to see if the code works before pressing the arrow key again.
Press the # button on the remote control when the TV turns off ot lock the code.
For codes and more details, Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | Sanyo Televison & Video
What to do if television becomes "bloqueado"?
Reset your TV to factory default. use your user manual some tv's you have to hold down the up button and power button at the same time or go into the manual by pressing manual button
Apr 11, 2012 | LG 32LG30 32 in. LCD HDTV
No power to my DP 19649 Sanyo TV. Where is reset button? Manual doesn't mention one.
There is no reset button
The hard reset process is to disconnect power for 1 hour then reconnect
Feb 19, 2012 | Televison & Video
I just purchased a universal remote and programmed it to my Apex and I can't get the cable to work I can't get it to go off mono what do I do?
Make sure your TV is set to Cable (Manually), Then with you TV on, hold the cable button down, and keep pressing the power button, till the TV shuts off...this should set your remote to cable mode! When you turn back on, press cable button then power!
You may have to repeat the steps, for the TV to come back on, to re-program your remote!
Hope this Helps!
Sep 10, 2011 | Apex Digital PF2725 27" TV
I can't find the manual power button on my Apex
The power button on the tv is is on one side. It is usuly on the right side.
Sep 03, 2011 | Apex Digital LD4088 LCD TV
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
