Question about Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
  • 57 Answers
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
Posted on May 26, 2011
My whirlpool gold refrigerator will not cool. Only the bottom freezer works
Sometimes when the freezer door is cracked open a bit for too long, ice forms inside around the vent. I believe the fridge is cooled by the freezer air coming through that vent. Defrost the freezer completely, about 36 hours, and wipe it around till it is clean and dry. Then turn it back on and just wait... My Maytag fixed itself that way, and it took a few days to get cool to temp again..... Good Luck!
Feb 03, 2016 | Whirlpool Refrigerators
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Why does ice keep forming in the bottom of the freezer and how do we fix the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator part does not cool but freezer part does.
check to see if the evap fan is blowing behing the freezer wall. if not it may need to be replaced. is there ice forming on the wall of the freezer? If so you might have a defrost problem.
Sep 17, 2009 | Freezers
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
548 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
