Question about Directed Electronics DV2602 Car DVD Player
What radio station do i use for the audio on my directed dv2602 system that is set up in my vehicle?
How do I use the Pre-set function for am & fm radio stations ?
press and hold the button you want to assign a station to.
Apr 13, 2016 | Car Audio & Video
How to tune in radio stations on a mini system without the remote
Hi, with just the controls on the unit itself you cannot set the radio station presets. They are set by holding down one of the numbered keys on the remote while in radio mode. The letter P with a flashing number will show up on the display to indicate you are setting that preset, radio will stop flashing and station will be locked into memory.
Aug 21, 2013 | JVC FS-2000 Shelf System
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
How to set radio stations
if you don't have all the power wires hooked up it won't save the stations, you should have a low volt wire just for memory status.
Aug 24, 2009 | Panasonic CQ-C5310U CD Player
Y sony direct comparator st s444 es 2 does not hold radio stations. Once power has been turned off for more than a couple hours, memorized radio stations are lost. Thank you
You could try looking for a memory retention capacitor on the circuit board. It will be on the board with coils etc. They sometimes are marked on the board. However they look like squashed electrolytic caps. They have a value of between 0.022 and 0.047UF and a voltage of around 5.5 volts. If you see one like that and it's near an IC then you found the trouble, replacement should stop the loss.
May 15, 2009 | Audio Players & Recorders
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Oct 20, 2008 | Becker Car Audio & Video
Audio System
Had you tried to go to a dealer? or a mechanic?
Jun 09, 2008 | 2001 Saab 9-3
Directed Electronics DV2602 Car DVD Player Logo
37 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
