Question about Hotpoint RVM1435 Microwave Oven
How to clean the filters? - Hotpoint RVM1435 Microwave Oven
  • 57 Answers
The only filter that you can clean are the ones on the bottom of the unit...but if they have never been cleaned it is better that you replace them. As for the carcoal filter, that cannot be cleaned it will have to be replaced. To gain access to this filter you need to remove the top panel across the front of unit. Two screws hold this panel on and once they are out you may have to slide it to the side slightly to remove.
Posted on May 26, 2011
How do I clean the filters
remove cover after remove filters you should clean the filters by water based detergent
Oct 24, 2014 | GE Spacemaker JVM1540 Microwave Oven
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
My menumaster UC11E2 continually shows "cln fltr"
The filter is on the buttom of the front door. take it out and wash it. Just look under the door.
Apr 10, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
HOW DO I GET FILTER Problem with the Microwave Ovens HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
I am a little confused as I don't ever remember a microwave oven with brown water a filter and cleaning tablets!
Jan 01, 2011 | Microwave Ovens
Filter care light comes on when it tries to heat up. hoover condenser dryer model hnc170-80
I expect the filter needs cleaning in that case.
Clean the filter and that should fix that.
Dec 28, 2010 | Microwave Ovens
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
127 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
