MY AUTOCAD PROGRAM OFTEN STOPS RESPONDING - Computers & Internet
  • 942 Answers
Try to check if that is the only program that stops functioning or there are other programs that stop as well. Better yet restart the computer and check if it will run again.. If not, check if you have the Autocad installer program, try to uninstall/reinstall it and check if it will run again...
Posted on May 26, 2011
  • 639 Answers
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and Login
Now, Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
Is windows 7 home premium compatable with autocad architecture 2015?
not good, you should upgrade to ultimate version for a professional use.
Aug 08, 2014 | Autodesk 057G1-G25411-4001 AutoCAD LT 2015...
Tip
How to avoid losing your work in case a program stops responding
Sometimes, while doing some specific work on your PC or browsing the internet, the program you're using suddenly stops responding without any apparent reason. If you hadn't been saving your work regularly, you'll most likely lose it when Windows prompts you to close the program.
There's however a solution that could help you avoid such frustration. Here are the steps to follow in case a program stops responding :
1. Once you encounter such a problem, don't close the program you're using.
2. Open the Task Manager by pressing Ctrl + Alt + Delete.
3. In the "Processes" tab, find "explorer.exe", choose it and click "End Process" on the bottom right.
4. Click "Yes" (Everything you see in the background will disappear but don't panic, it will come back).
5. Click "File" on the top left.
4. Choose "New Task (Run...)"
5. Write "explorer.exe" in the box.
And everything comes back! You can now resume your work...
on Sep 28, 2010 | Computers & Internet
AutoCad
Hi, does your PC support the software, you should have atleast 1mb ram and a graphics card.
Jun 20, 2013 | ASUS P5KPL-AM SE Motherboard
Code activation
Before you can use the AutoCAD 2007 software on your computer, you must import your license key into the program.
You received this license key after purchasing your copy of the software.
This key confirms to the software that it wasn't pirated, and allows you to use all the features available to you in the AutoCAD 2007 software for whatever length of time you choose
Open AutoCAD 2007 (if you haven't already) using the icon in your "Start" menu.
Click "Edit" at the top of the "AutoCAD 2007" program window.
Click "Options."
Click "Registration."
From this window, click "Activate Now."
Type your license key into the window on the screen and click "Activate."
This will import your license into the AutoCAD 2007 software.
utoCAD 2007 Tutorial - User's Guide
http://www.tutorialspdf.com/autocad-2007-tutorial/
Jun 03, 2013 | Autodesk AutoCAD 2007
When save as autocad not responding
Are current with Updates and Service Packs?
Have you tried to PURGE and AUDIT the drawing?
If none of those work, try checking in with the AutoCAD Community for additional visibility.
Philip
AutodeskCare' Community Manager
TW ' PI ' YT ' BLOG
Oct 09, 2012 | Autodesk AutoCAD 2010
My autocad cant start because ac1st16.dll is missing. what should i do? please help me guys...
If you get the above error, copy all the files from C:\Program Files (x86)\Common Files\Autodesk Shared to C:\Program Files (x86)\AutoCAD LT 2004 For some reason, AutoCAD installs the DLLs in the Autodesk Shared folder, but needs them in the AutoCAD exe folder location. Hope this helps! Ben
May 21, 2012 | Autodesk AutoCAD 2006
When I open a file that is associated with autocad, autocad opens the file and the program at the same time. But if I already have autocad open and click on another file, instead of autocad opening that...
Turn off your single document interface. Type OP and hit enter. Then select the system tab and check off the SDI (it should be towards the upper right of the dialogue box.
Nov 24, 2009 | Autodesk AutoCAD 2006
Opening dwgs in autocad
In the past the fastest way to fix this is to go directly to the file and try to open it. It is possible that file or database has been corrupted. In some instances the file type dwg is not associated with autocad and the application hangs because it is looking for .dwg as an associated file type to autocad.
Let me know if you need further clarification.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
