Can you get an HDMI Input into the sony klv s40 a10
  • 927 Answers
Good Day, aforrest;
If your TV does not have a HDMI input on the back of the TV then your TV can't perform this function.
Good Night & Luck, big IRISH.
Posted on Aug 16, 2008
Klv 40s400a
TVs need an input to display a picture. Some TVs have several inputs and you must select the one you are using. Example: my TV has four HDMI inputs on the back. If I connect my PC to one of the HDMI ports I must select that input in setup to display My HDMI ports are labeled HDMI 1, HDMI 2, HDMI 3, and HDMI 4.
If I connect my PC to HDMI 3, I must select in setting HDMI 3 as the input.
Oct 16, 2013 | Televison & Video
Pc in problems no signals sony bravia klv-32 ex300
Plug your video cable from your computer into a known working monitor first to make sure the cable / computer video work.
If this works, unplug all cables from your tv, except the power, and plug in the pc video. Make sure to use the menu to select the correct input (should say "pc" unless you are using hdmi cable, then you select the hdmi input (hdmi1, hdmi2, etc).
Mar 02, 2013 | Televison & Video
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
MY SONY BRAVIA MODEL NO. KLV-32BX300 ARE NOT PLAYED VIDEOS IN FLASH DRIVE WHICH KIND OF VIDEOS ARE PLAY IN THIS MODEL PLEASE HELP ME FOR THIS PROBLEM
"Bravia Engine 3; built-in FM radio and clock; onboard JPEG, MP3, MPEG-1 and MPEG-2 playback via USB; 1080p24 input-ready; Bravia Sync (HDMI-CEC); dual HDMI terminals."
May 05, 2011 | Video Game Consoles & Games
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony bravia klv-32t400a hdmi input through x-box and p.c gives error reading - unsupported signal! check device output. both are on 1080p using hdmi to hdmi cable v1.3 why no vidio, only audio
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Mar 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HDMI input problem
either its hooked up wrong..in the wrong slots, or its not plugged in all the way, those are two of the most common problems
Jan 06, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
HDMI and other outputs doent work
You may want to try a Manufacture reset. To do this you must first turn the TV off. Press in sequence.. Display-->5-->Vol +-->power on your remote(this sequence must be done fast). This should bring up a service menu. Press the number 8 and then Enter on you remote, The set should go off and on by itself. Now go through your setup and try the input again.
Best regards
Circuitcity
Dec 06, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
