Power is connected and printer is on; printer cables to pc is connected however this message keeps coming up to check them....and the print wont print....what can I do?
  • Doc820520902 May 26, 2011
    What Operating System are you using? What brand and model is the printer? Is this printer new or used? What cable is connecting your computer to your printer i.i Ethernet, usb, etc?
    Sergeant:
  • 207 Answers
It could be a driver problem where the computer system won't able to detect the hardware completely. Try installing the driver of your printer and try using other ports if it is a USB one.
Posted on May 26, 2011
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Red light flasing and printer wont print
Remove all the Cables keep pressing the power button. this is easy way to remove all the power from the printer. Make sure there is no Paper jam and roller is clean to your best extent.( Dont try to be smart her ). Remove the ink toners. reseat the cables. Connect to Computer. Power on teh Computer First. Now poer on the Printer.
Let it ask for the Ink Cardridge. It shall come to Normal behaviour and PRINT. Let me know if you need explainations. I will check the comments. make sure you rate this solution. to get in touch.
Happy Printing.
Sep 12, 2010 | Epson Stylus NX100 InkJet Printer
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
It wont print
you see what it imply is that it a software problem so what you will do is find the printer driver that come with your printer and install it. if it new you buy it software most come with it but if you have done it befor. it means you have not install the driver properly. i will like if you can uninstall the driver then reinstall is back. those devicese take deferent way of installing their drivers some what you do is befor connecting the cable to you pc install the driver on the pc first while other you will connect the device to your pc then the installation wizerd will promt and ask if you will do the intalation manually or authomatically you will just follow the questionair.
Nov 17, 2008 | Lexmark X75 All-In-One InkJet Printer
Spp 2020
check your windows settings
and   even if thos are correct maty be the connecting cable is not workinfg
Sep 06, 2008 | Samsung SPP-2020 Thermal Photo Printer
Printer wont print
have you removed the protective tape on the nozzle and copper contacts of the printers? while the printer is on, remove all the cartridges. now unplug the power cable from the rear of the printer. the printer would power off. now press the power button 10 times. now plug back in the power cable and replace all the cartridges. now try to print.
Aug 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Jan 03, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Print wont print
Hello, You may check to insure the USB cable at the printer or at the computer is connected properly and didn't come loose by chance. Try disconnecting the USB cable from the computer, wait ten seconds then reconnect. This will let Windows "find" the printer again. Worse case scenario, you could delete the printer through device manager, reboot you computer and Windows will "find" the printer and reinstall the driver automatically on restart. Also check that the ink cartridge(s) is seated properly.
Jul 18, 2007 | HP DeskJet 3650 InkJet Printer
27 people viewed this question
jasbo
jasbo
