Question about Car Audio & Video
I would like to install this deck to an old 1974 chevy sports coach RV that still had the oem 8 track player in it. I got the old deck out and fit the hole for the new one. Then I began to try to figure out the wiring...well the rv has 3 black wires, 1 blue and one red coming out of it. I know the blue and red are for right and left speakers and it appears two of the black one converge together and route to a speaker switch to control the front and rear of the vehicle. That only leaves me with one black wire left as the power source. Basically, I am lost at this point and wondering now if it is even possible to hook this thing up here. There is no wiring harness on the RV...it was simply these wires running directly to the old deck. Any help would be appreciated...
  • Chris Fisher May 27, 2011
    The current wiring has 2 speaker wires...one for front and one for rear. The stereo has 8 speaker wires...a positive and negative for both front and both rear. How do I wire the 4 speakers that only have two wires at the front? Or do I assume the speaker wires are split and just wire in 1 front and 1 rear from the deck?
  • 11,800 Answers
Put the contact on the ignition key and use a multimeter set on voltage to locate the power wire - it will be the only one with 12 volts on it. Then determine if the system uses a separate ground wire or the grounding is done thru the metal fitting on the hole - set the multimeter on resistance and measure the resistance between it and another part of the body, it should be less than 0.2 ohms. Then locate the speakers wires - you will locate one when the resistance between the wires and themselves or the ground will be 4.5 ohms. That is all.
You will have to add a radio antenna with its wire yourself if you need it.
Posted on May 26, 2011
  • Azrael SRL May 27, 2011
    The new stereo has the capability to power 4 speakers so it has 8 wires for them: 4 for the outputs and 4 for the ground. In your case the ground wire is not there it has been replaced by the body so the 4 ground wires in the stereo connect to the body. For the rest, you do not need to connect all of them - you could connect just one of each (as you thought). But the best solution is to join the 2 front and rear wire outputs on the stereo and make them drive (connect to) the single front and rear speaker in your RV
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
WHAT KIND OF TRANSMISSION IS IN MY RV? IT HAS A CHEVY 454 ENGINE.
454 chevy engine in motorhome - RV-Coach Online
www.rv-coach.com > Discussion Forum > Mechanic's Corner - Engines
Mar 25, 2010 - I have a 1995 winnebago elanden Chevy chasis and Chevy 454 motor.... I am trying to tighten or replace all the belt on my 1987 Fleetwood Southwind ... What type trans fluid,oil and filter does the 1984 chevy rockwood motorhome take? .... Havereplace ignition switch, check neutral safety switch at transmission, all OK. RV with Chevy 454 engine problems
Oct 18, 2015
454 P30 radiator removal
Jul 23, 2012
Overdrive Transmission Conversion
Nov 6, 2010
4L80E Transmission Problems
Nov 15, 2009
Nov 24, 2015 | Cars & Trucks
I need the schematics for 79 coachmen cadet
Re: 1979 Coachman Cadet Manual
www.rv-coach.com > Discussion Forum > RV - Class A Motorhomes
Nov 11, 2010 - Re: 1979 Coachman Cadet Manual, Pat McKeon, 10-18-07. Reply to Message, Re: 1979 Coachman Manual, Faye Anderson, 2-8-04. Reply to Message ... 1979 Coachman cadet Manual - RV-Coach Online
Apr 1, 2012
1979 Coachman Cadet Manual - RV-Coach Online
Nov 13, 2009
Manual for 1977 coachman cadet 21-22 ft trailer - RV-Coach Online
Aug 9, 2005
Oct 31, 2015 | Garden
Flat screen power adapter
There are no such things as 8 track movies or tapes. You either have Beta , VHS or 8mm cartridge and those machines are hard to find these days in working order. The only other cartridge is U matic bu they are no way near a 8 track size tape.
Mar 01, 2014 | Audio Players & Recorders
What do we do if weve put a formal complaint about a under 7s football coach who is bullying the players and swearing and threatening the parent and the football president isnt doing anything about it
I would recommend gathering evidence and contacting local police, as well as encouraging all of the parents to pull their children from the sport into the issue is solved.
Jun 12, 2013 | Video Game Consoles & Games
Hi, I have a Tascam CD-A500 combo CDplayer/cassette recorder. The CD player has started skipping with very minimal vibration. This is new and never had these problems before. It is the most sensitive when...
Laser assembly is losing its ability to properly focus on the disk surface. It is going to La La land and needs to be replaced.
Get another player since repair is not cost effective.
Mar 19, 2017 | Tascam CD-A500 CD Player
What kind of adapter to install cd player into 2000 malibu
what you will need is the radio adapter kit for your car make. also you need a wiring connector for the car between car wiring and radio. match the wires to wires on radio, and then the connector will fit car wiring connector, just plug it in to car wiring.
May 07, 2010 | Corvette Chevy Malibu 90-04 Car Radio...
How to install a factory 8 track tape player in a 1967 cama
CANT HELP U W ANYTHING AS OLD AS AN 8TRACK PLAYER MY GUESS IS U BEST BET WOULD BE TO AT SOME SALVAGES FOR YOUR BRACKET
Feb 11, 2010 | Car Audio & Video
Firing order for a big block 440 from a Sports Coach rv Also I need the Parts breakdown for the carb. Thanks
The firing order for that motor is 1-8-4-3-6-5-7-2 The carb is I imagine a carter afb or similar four barrel here is a great link to carter carbs copy this entire link into your address bar
http://www.rodandcustommagazine.com/techarticles/135_0402_four_barrel_carburetors_howto/index.html
I hope this helps you.
Aug 14, 2009 | Chrysler Executive Cars & Trucks
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
