Question about Fuji FinePix A820 Digital Camera
When i was using the rechargeable batteries my camera worked fine but i lost them so i reverted to use duracell aa batteries and now my camera only turns on for me to see all the pictures stored on it.. i cant even take a picture. can u tell me wats wrong because i thought all camera take any aa batteries
    Master:
  • 346 Answers
Greetings - You're absolutely right - Your camera should work with any rechargeable or alkaline AA batteries.
Have you tried using a second set of batteries besides the first and are they new batteries or batteries that have been lying around in a drawer?
If they're new you might want to try an old trick that might help and get a regular pencil with an eraser and use the eraser to clean the contacts on both ends of the battery compartment. When you're done make sure you blow out any bits of eraser that might have crumbled off.
If the batteries are new and the contacts are clean your camera has some kind of problem and I suggest you visit Fuji Films tech support website HERE.
Good Luck,
Mikeywaf
Posted on May 26, 2011
Batteries good, but screen shows :batteries empty?
How you know batteries are good? Sometimes new batteries are bad too. Also there is a possibility that you are using wrong type of battery like normal carbon batteries or lower ampere batteries which work fine in other gadgets but will show empty in a digital camera. Digital camera need high ampere batteries like Duracell (if your camera use AA batteries) or rechargeable NI-MH/ Li-ion batteries.
May 12, 2011 | Cameras
Which battery should be used because i used battery which was hardly luseful for one day.
Hi, Please use AA NiMH batteries You can find these batteries Duracell AA Rechargeable NiMH batteries DC1500 they will run you longer! You can find them in any Walmart near you. Remember you will also need a charger for them.
I hope this solves your problem for ever! Please thumbs up if this works for you!
Dec 24, 2010 | Olympus FE-310 Digital Camera
What kind of rechargeable batteries do I get for my camera? Kodax Easyshare C875
You can get any type of AA rechargable batteries. Doesn't matter what brand as long as there are AA. You can get a charger/battery kit from amazon.com or newegg.com
Oct 23, 2009 | Kodak EasyShare C875 Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Camera shuts itself immediately after starting it
Did you try using the coolpix batteries that came along with the camera? check the ratings on coolpix batteries and compare them to the batteries that you are using now.
Mar 23, 2009 | Nikon COOLPIX L10 Digital Camera
Batteries
I use Duracell 2650 mAh rechargeable AA's with my 283 all the time. You may read that 1.2v Duracells or other rechargeables will not work because of the slightly lower voltage (alkalines are 1.5v).
I believe the problem lies not with the voltage, but is due to the slightly fatter profile of the rechargeables that causes a tight fit in the Vivitar battery pack. I find that, after inserting all four (the last will go in really tight), I need to give each cell one more firm push so that it seats properly into the battery pack.
Good luck.
Caruso
Oct 13, 2008 | Vivitar 283 Flash
1.5 AA battery
if they fit ..yes you can make sure they are inserted properly ..also if using regular alkaline ,I only recommend duracell or high output camera rechargable batteries
Mar 28, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
FinePix E500. 4.1 : model # BL00402-200(1) E
Indeed you can!
I would recommend against using any of the older NiCAD batteries, however.
The newer (and - BY FAR - more efficient) standards is NiMH batteries. (Nickel Metal Hydride.)
I used to be an Energizer fan myself... But as I worked in electronics retail, I tried many different brands of batteries with our products. I actually hated Duracell because of the crap quality of their older product lines.
But eventually, I had to grudgingly admit that Duracell batteries were far superior to any other brand currently on the market. (No less expensive, however. Pretty much the same price.)
I use the 15-minute charger currently available from Duracell. It cost about $30, but it comes with 4 AA batteries with a rating of 2400 mAh.
This rating is basically what determines how much of a charge the battery can hold. The higher the rating, the longer the battery will last.
I also bought an extra pack of 4 AA's while I was at it. I bought all of this for my digital camera. (Canon S3 IS.) The batteries in the extra pack had a higher rating of 2650 mAh.
Even using the 2400 mAh AA's, my camera lasts for a few DAYS of continual use! I will admit that I rarely use the flash on my camera. But even with the flash, the batteries last several hours with continual use. The 2650 mAh batteries last even longer. (Yes. I have monitored and recorded usage vs endurance. I know. What a nerd I am, eh? :P )
Perhaps you've had bad luck with Duracell before, but so did I. I'm still not too fond of their alkaline batteries, either. Perhaps you should consider giving the Duracell rechargeables a try?
Click HERE to see the product I bought on Best Buy's site. (I bought mine at Walmart, however.) It is the 15-minute charger system. It works with both AA's and AAA's. (I had to really inspect the device after I bought it to see how it recharges AAA's though. But it works great.) It actually does charge in 15 minutes, too. Every time. It's so powerful in fact that it uses a fan to cool the batteries while it's charging. Now that's awesome. :)
Remember to make sure that you give the batteries a full charge before you use them. Also make sure that you don't charge the batteries again until they're completely drained. Otherwise you will significantly decrease the charge capacity of the battery. Duracell has an excellent guide on their site on how to lengthen the life of your batteries. (I just found it trying to look on their site for their own product...which I did not find. Good batteries, crappy web site. Bleh...)
Click HERE to see this spiffy guide. It actually contains excellent information.
Otherwise, you can try any other brand that you prefer. Energizer is still second best, followed by Rayovac. (This is from my own experiences, of course.)
Let me know what you think. :)
Cyryl
Nov 10, 2007 | Fuji FinePix E500 Digital Camera
Fuji FinePix A820 Digital Camera Logo
50 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
