Question about Maxtor DiamondMax® 10 (6V300F0) 300 GB SATA II Hard Drive
I have problem with maxtor 6v 300F0 - Maxtor DiamondMax® 10 (6V300F0) 300 GB SATA II Hard Drive
  • Maxtor Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function
also run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Posted on May 26, 2011
My child was given this keyboard, but it is missing the DC 6V adapter/charger. It looks like we will have to purchase a generic 6V adapter but do I get the 6V 1A or 6V 2A? Thanks in advance!
The keyboard's input should give you the amperage requirement. If not there, get the 2 amp just to make sure it will work. The higher amperage of unit will not harm it if unit calls for 1 amp.
Jun 08, 2016 | Computers & Internet
Hi, I have a mission cop 2,000,000 and I lost the charger, can I use a 12v 500mA as a replacement? Note that the battery is a 6v
Hi Ebrahim
Defiantly not you cannot use a 12v supply on a 6v battery in the worse scenario you could blow up the battery by putting to much voltage into it, you will need to find a 6v charger hope this helps
Dec 17, 2014 | Toys
Ford naa 6v
you will get much more than 6v at the plugs when it is working more like 16000 v. Check that the condenser is working and has not failed as it is vital to make the coil work properly.
Jun 03, 2013 | Ford Tractor Naa Golden Jubilee Emblem
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
How do i wire my golf cart for one light and one horne 6 volt batterys 36 volt system
The batteries are connected in series (6V + 6V+ 6V +6V +6V +6V), Select only two batteries (CONNECTED TO EACH OTHER in series FROM POSITIVE TO NEGATIVE (last two batteries preferred) and run two wires (one black one red) from the positive (red) and the negative (black). purchase two switches one MOMENTARY PUSH BUTTON AND ONE TOGGLE. Split the two wires by ADDING another length to the middle of each wire respectively Add the switching devices by connecting the red wire to one of the terminals. The other terminal will then receive Another length (red) to be the connected the same way to the horn (push button switch) The black wires (ground) are to be connected to the other terminal of the horn and light. NOTE: it is advisable to add a 15A in line fuse to the red wire near the battery.
Oct 14, 2011 | Sport & Outdoor - Others
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Ignition Coil for Honda 125 CM /84
The 12v coil on a 6v system will only give a weak spark at best. The coil in the photo should work very well assuming the wires are long enough. Any 6v twin coil should work. If you fit another coil and the bike has spark but will not start, swap the wires at the points. Don't purchase a condenser unless the old one has gone bad. If needed, get a 6v condenser matching the old one.
A “very helpful” rating for this answer? Thanks from Dallas Texas!
Jun 16, 2009 | 2000 Honda CM 125 C
Rechargeable battery
Hi, try looking on ebay, user name; itl-e. His shop name is; Component-shop. A wide range of batteries supplied including a 6V 5AH which sells for about £8 including p&p. Your Panasonic battery is rated at 6V 4.2AH, so the replacement will last slightly longer between charges. If you want an exact (Panasonic) replacement, try putting "Panasonic LC-R064R2CH into google.
Hpoe this helps! Bob.
Oct 05, 2008 | VAX Appliances V037 Stick Wet/Dry Vacuum
Maxtor DiamondMax® 10 (6V300F0) 300 GB SATA II Hard Drive Logo
94 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
