Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front load washer
The water in the washer won't drain and the clothes are soaking wet!! Plus all the lights are on when the cycle is done?? Help Please..
  • 3 Answers
Going to take a little surgery. Most likely a small sock or other article made its way down the drain pipe and clogged against the pump.
I have a Frigidaire Gallery Series front load washer. I've had to do the following at least six times in the last year and a half. Each and every time, it was an errant sock from my three year old.
First, unload all the wet clothes into a garbage bag. Then **** out all the water using a wet/dry vac. You need to do this for safety reasons because you're going to be tipping the washing machine back and having water slosh around could cause it to fall on you.
Once you've sucked out as much as you can, pull the washing machine out from the wall by about three feet. Then with the help of someone, tip it backwards so that it rests against the wall. Have your friend hold it in place.
At the bottom on the front are two screws holding a panel on. Remove those to gain access to the guts.
If you look to your right side you'll find a pliable rubber boot mated to a hard plastic pump. Using a pair of channel locks or other suitable pliers, squeeze the wire clamp down and pull towards yourself. Be prepared for some water spillage when it comes off. I usually put some towels under the pump area and then use the wet/dry vac to **** the rest of the water out of the rubber grommet area.
Once this is off, you'll most likely find something clogging up the pump (the hard plastic part). Pull that out and essentially reverse your actions up to this point to put it back together. I will warn you it takes some patience to get the pliable rubber boot and clamp back in place on the pump inlet. Sometimes it takes me four or five attempts and I've done this a few times already. The key is to make sure you've made a good seal and the wire clamp is holding securely.
If you bought the under washer/dryer storage boxes, you might be able to get away without tipping it back, but I don't know for sure. The important thing is to try and get as much water out as possible.
Good luck.
Posted on Aug 18, 2008
  • Tom in MI Oct 17, 2010
    This worked like a charm for me. There was a small piece of fabric/yarn/string that was stuck in the inlet of the pump. I removed it and now the washer is working fine.
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Regards
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
FRONT LOAD WASHER
ther is something blocking the drain pump, check the water coming out from the drain if its floating out good if not there may be a sock or a bra wire inside the pump.
Apr 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
160 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
