Question about Video Game Consoles & Games
I am getting a status code after trying to download the system update from Xbox. The status code is 3151-335A-1380-2203-C000-0001. What can I do to get around this?
  • 3 Answers
You buy that Xbox used? 3151-335A-1380-2203-C000-0001 is the reference code for an Xbox that has been modded and/or hacked. Basically if the seal in the Xbox has been broken and now you are pretty much SOL.
Posted on May 26, 2011
3080-351f-1600-2203-c000-0001
Posted on Sep 16, 2011
2 Suggested Answers
SkotConCarne
  • 3 Answers
SOURCE: status code : 3151-335A-1380-2203-C000-0001
Did you buy that Xbox used or have it fixed somewhere? Because the seal in your xbox was broken and now the xbox thinks it has been modded and/or hacked and you are SOL.
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
Xbox360 update download failing
This usually happens when the Xbox does not have enough space to save the update to in order to install it. Make sure you clear out enough space so you are able to properly install the update.
Here is a list of other errors that can happen to system updates.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Contact back with the code you get if you cannot fix it using Microsoft's tips and I will try to help.
Apr 08, 2014 | Microsoft Xbox 360 Console
Status code 3cd6-3f45-b680-0f00-c000-0034 xbox
try holding the sync button in on your console and power the console up do not release the sync button until the console has fully booted up if not try calling xbox they can usually walk you through this problem
Nov 21, 2012 | Video Game Consoles & Games
Its give me a status code
Hello Mark Swift,
It seems as if the status code "3151-351f-b800-0402-c000-016b" is an error code resulting in a failure of receiving an update directly into the cache of the console. This also may be the cause of trying to install custom firmware. I cannot guarentee this will work, but try downloading the Xbox update from Xbox.com onto a CD and inserting it into your Xbox console to download it. If this does not work, message me back, I will keep track of this problem.
P.S. I cannot provide you with a direct link to the update because Xbox.com is not working on my laptop wirelessly. Sorry!
Dec 05, 2011 | Microsoft Xbox 360 Console
Wont download an system update keeps giving me status code
Try these in this order
Clear your cache
Format your hard drive (backing up what you need of course)
Call xbox support 1-800-4MY-XBOX (1-800-469-9269)
Nov 26, 2011 | Microsoft Xbox 360 Console
My xbox 360 was updating and it stoped and froze, its says my system update failed status code 3151-351f-b380-0402-c000-0001
According to the Xbox Support page, you should contact Microsoft about this error. http://support.xbox.com/en-US/contact-us
Other than that, I would suggest trying to update using different methods. If the problem occurred while updating from Live, try putting the update on a disk or flash drive. Here is a link to the update page where you can find the downloads for disk and flash drive. http://support.xbox.com/en-US/xbox-360/how-to/update-xbox-360/system-updates
Good luck.
Sep 29, 2011 | Microsoft Xbox 360 Console
I tried to update the xbox but ot can`t read the update from the disc. Status Code: 3151 - 335A - B800 - 0F00 - C000 - 0034
if your system is modded with a custom firmware then you must update your custom firmware first
if your system is not modded then you must update your system manually by going to xbox.com/support and download the latest update file, use a USB to finish the update
Thanks
www.1RepairStop.com
Sep 18, 2011 | Microsoft Xbox 360 Console
Xbox 360 support status code 3151-335A-B800-0F00-C000-0013
The update was interrupted, the best way to clear that code you must update your system manually. got to xbox.com/support and download the latest update files. use a USB drive to finish the update loop.
thanks
www.1RepairStop.com
Sep 14, 2011 | Microsoft Xbox 360 Console
When i try to play dead island it shows: cant read the update from the disc..status code:3151-335A-B800-0F00-C000-003A
Your best way to update your system is manually, go to xbox.com/support and download the latest update file. use a USB drive to finish the update.
Thanks
www.1RepairStop.com
Sep 10, 2011 | Microsoft Xbox 360 Console
Status Code: 3080 - 0000 - 0080 - 0300 - 8007 - 2EE2
If this is an error while trying to update your system, follow the link below and attempt to update your system using the USB method
http://support.xbox.com/en-us/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx
Aug 23, 2011 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
2,812 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
