Question about Cannondale Cycling
Frame makes noise - Cannondale Cycling
    Brigadier General:
  • 8,546 Answers
Creak'n-dale?
If it's drive-train related ...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Depending on the BB style you might also consider putting that white thread sealing tape in there.
Make sure your seatpost is greased well, too.
Loose chainring bolts will cause noise, too.
Good advice here...
http://forums.mtbr.com/showthread.php?t=405413
Posted on May 26, 2011
Wind noise 2011 volvo s60
possibly a partially open window or partially open sunshine roof.
Mar 12, 2015 | 2011 Volvo S60
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Ground connection
I'm not clear on what you are referring to. This is on a lawn tractor- correct? And there is a poor ground connection on the negative battery cable to the frame? Also, I'm not clear what you mean by " to make any noise". DO you mean to start the tractor? If this is the case- make sure the battery cables and the battery posts are clean- very clean. Clean the frame where the negative cable attaches, and clean the cable end. All connections need to be clean - no rust or corrosion. The negative cable can be attached to the frame at any point, so the cable can be moved by drilling a new hole in the frame, but usually this is not necessary if the original hole is cleaned of rust. If you need further help let me know.
Apr 03, 2014 | Garden
6000 Series Rattle & Vibration
Sounds like the drum wheel or wheels need replaced .The twist frame thing just doesnt line up sorry ..LOL
Aug 19, 2013 | Maytag Dryers
The fan motor makes a noise when it's running. I'ts 7 yrs old.
The noise could be the blade is coming loose on the shaft. It would need to be tightened. Or it could be it is striking the frame.
Feb 21, 2013 | Maytag Freezers
Freezer fan makes noise
check to see if the fan blade is touching the frame and adjust. if its not touching anything but making noise change the fan
Jan 16, 2013 | GE GSH25JFT
My toyota hilux d4d makes a noise from dashboard when i take off from stop, what should do to stop noise?
I had a noise dash and when I removed the sat nav I had loose connections knocking against the metal frame , secured them and no further noise. Hope this may help.
Nov 28, 2012 | Toyota Hilux
ICE MAKER MAKING NOISE BUT NOT MAKING ICE
What sort of noise?. If it's a buzzing noise, it could possibly be the hot gas solenoid is still energised, thus defrosting the ice frame.
Apr 17, 2010 | Amana AFD2535DES French Door Refrigerator
The motor on the windows make noise but the glassdoesn't move
The window actuall sits in a frame inside the door and the motor raises and lowers the frame along with the glass. The arms which connect the motor to the frame can become detached and as the motor runs only the connecting rod moves but the frame holding the window stays in place. If you can reve the interior door panel you'll see exactly what I mean. You may even be able to repair it yourself. If your hesitant about removing the door panel take it to a mechanic or dealer.
Dec 19, 2009 | 1994 Lincoln Town Car
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Cycling Logo
451 people viewed this question
Top Cannondale Cycling Experts
John Egan
John Egan
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
