Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba 65HX81 No Power Issue
TV worked great then all of a sudden no video or audio(black screen). Press Power button and light turns red and you here a click in the rear of the tv and then nothing. I am not getting any blinking like others have commented on and I have checked all of the fuses that I can find. I am still searching for schematics. I have looked over the boards and don't see anything fried at all. Any help or suggestions would be very much appreciated.
  • jordanjcm Aug 31, 2008
    I am trying to find the fuses in my 65hx81 toshiba. fuses f889 f890 and f891 but I dont know how to find, check or replace. Please help me. PLEASE. I was told because my left side speaker has blown ( the speaker itself does work, I took it out to make sure, but the tv will not power it.) and I was told I need to check these fuses.
  • 1,800 Answers
Ur ignition card/panel is burned change it!!
Posted on Aug 16, 2008
Dear Jimmy, I have a 50PA4500-UM from LG. It has sound but black screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 20, 2017 | Televison & Video
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red light blinking and no picture on Toshiba Model 65HX81 how do we fix?
Red power light blinking is shutdown--protective mode.
Before buying a remote I would see what is wrong with set.
The most common reason on this model is a short in the convergence circuit--uses two chips----method to see if they are shorted is to locate (not real easy on this model) and unsolder all 18 pins on each chip--if set turns on then(will look bad) one of the chips is gone and both need replacement.
The other issue this set has is bad Hyper boards that cause noise when cold and operate after warmup---more expensive to fix than a convergence problem.
convergence chips used in this set look like these
Mar 30, 2012 | Toshiba 65HX81 65" Rear Projection...
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
Toshiba no video
how do i turn on my toshiba big screen tv red light blanks button want push in
Apr 22, 2008 | Toshiba 43H72 43" Rear Projection...
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
