Question about ASUS P5KPL-AM SE Motherboard
If the power push botton is on no power but the power supply are ok.
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 26, 2011
WHEN POWER BOTTON PUSHED ON TV IT DOSE NOW COME ON
Check and replace damaged component/s in the main power supply regulator board.
Oct 11, 2012 | TruTech Televison & Video
DE PUSH POWER BUTTON POWER COMES ON GOES RIGHT BACK OFF, IF YOU HOLD POWER BOTTON IN AND TURN KNOB TO A CYCLE THEN PUSH START BOTTON ERROR dE COMES UP
Check the outlet first. If the outlet is ok, then you have a control board issue. Replace the control board. Good luck.
Jun 19, 2011 | LG WM2487H Front Load Washer
Not turn on only clik
Goodday! what do you mean...! its not turn on when you clik it.? .......1st chek the power supply if its ok and plug...if ok then....try to clik it or press it more. check the push botton if not yet damage if not.! check the supply voltage if not yet working...if theres is a voltages....check for unusual sound or smell for burn chip or parts.if there is...? need for repair.......................in the speaker...! check the wiring if not cut or damage....check also the proper wiring or installation of your speaker maybe its not properly connect or wrong connections...! thank you..
Feb 13, 2011 | Car Audio & Video
My lcd tv keep flashing the on botton when i turn it on and there is no image,i have to keep pushing the on botton until the on botton light stay on and the screen comes on,
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
Nov 25, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
None of the bottons work, tried to cancel but off came on.
Ok, will it allow you to reset the clock? That has to be done before you can use the oven.
May 20, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Printer does not switch on - power cable is functioning and plugged-in.
Your Printer doesnot switch on, your Power cable is ok and plugged in, so your first you check the switch botton is ok or not. Internal wire may be diconnect from your printer Switch botton. otherwise your power supply board problem, so you change or repair the power supply board of your Printer. You will Check these problems, you must solve your problem.
Thank U
Aug 28, 2009 | Office Equipment & Supplies
My pc cannot turn on.
Get yourself a new one with new power supply new quad core new hard one terra evething new for a few dollars time change computers are something very different nowadays nothing to do with 10 years old machines....enjoy todazy life is not forever...;
Aug 19, 2009 | HP Hewlett Packard Pavilion Slimline...
Engine start then die
just push it to power bottom!switdh first in power supply
Mar 16, 2009 | Welding Tools
Power button won't shut off
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
ASUS P5KPL-AM SE Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
