Question about Washburn B9 5-String Banjo
Looking for a 5th string thumbscrew assembly for a washburn banjo. It is the part that inserts into the wood in the neck of the banjo and then you thread the 5th string into the assembly and tighten it with the thumbscrew to tune the string.
  • 73 Answers
SOURCE: string peg required for washburn d10b
http://www.stevesmusiccenter.com/EZPeg.html
A new type of peg that makes it easier to change strings!
Either that or most guitar shops stock string pegs, Just ask at the counter .. .If they don't have them and can't get any in then they are not a real guitar shop in my opinion
Posted on Apr 23, 2009
  • 10 Answers
SOURCE: Both the E and A strings
The neck may require adjustment, but would recommend taking it to a luthier or using a guide like raeguitars to talk you through it. Depending where it is on the fretboard that buzzes, the nut may require replacement/adjustment. I've had all these problems in the past and the above tutorial helped me fix all of them.
Posted on Nov 30, 2009
  • 5603 Answers
SOURCE: I need to replace a broken string on my Washburn
Try this site:
http://www.frets.com/fretspages/Musician/Guitar/Setup/SteelStrings/Stringing/ststringing1.html
Posted on Dec 28, 2009
SOURCE: I need a replacement neck plate for the Washburn N4
Hello, I actually have two extra necks that I bought on Ebay a very long time ago. No idea is they are original or not. I will post one of them on Ebay. I bought them for a project which I finished. I had also contact Washburn a while back because I was looking for the neck but they will not sell the neck unless you send them the body. They explained that each neck is fitted to the body. I believe them because none of my 4 N4 have the same neck. I can not interchange them. I am starting the bid on Ebay for $400. If you want the other neck let me know. info@pmpincusa.net
Posted on Feb 23, 2010
criss_michae
  • 63 Answers
SOURCE: ok so i was tuning my Warlock and was tightening
You broke the 'nut' of the guitar. These cannot be repaired, but they can be replaced. Most guitar shops, such as Guitar Center, Sam Ash Music, and Musician's Friend, carry these in stock. They are fairly simple to replace, and cheap to buy. I would get a few if I were you.
They come in quite a few different materials, as well as many different colors. For color, you'll want to go with what matches the rest of your hardware. If you have chrome hardware, a white nut is good. Black hardware calls for a black nut. As for materials, that's up to you. A GraphTek nut, made mainly of graphite, reduces string friction, but costs a lot more than your standard bone nut, and almost a fortune more than a plastic nut. Sounds like you had a plastic nut, which is good for a beginner's guitar. If you can swing it, get a bone nut. It will last longer, and helps out a bit with your tone.
For replacing it, just take your strings off, and swap them out. Some guitar manufacturers glue their nuts into place, so you might have to pry on it a bit. Be careful not to scratch your guitar. It will be easier if you take off the truss rod cover (the triangular looking piece of plastic at the base of the headstock). Then, you can get some leverage under the nut, without scratching an obvious part of the guitar. Still, be careful.
After you get the old nut off, you can either place the nut on there, and string it up, or glue it in. Wood glue is suggested for the second option, but you'll have to clamp it in place and let it set overnight. The next day, you can string it up and play again. Mind you, this option is NOT recommended if your band has a gig either that night or the next day.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Posted on Mar 27, 2011
Tune Guitar strings 1,2 & 3 to Banjo and play with finger pickers. Bass strings to accompany. Developed complicated chords (Including Bass strings) I need to record this on paper - any tips?
Are you familiar with Tablature notation. It's instrument specific and instead od a regular staff you maje a duagram od the instruments strings looking down on the neck and then instead of notes the number of the fret goes on the relevant 'string'
https://www.guitartricks.com/helptab.php
and it's similar for banjo. Google tablature explained and a page comes up with a selection of instrument tabs.
Sep 15, 2017 | Bass Music
Would like a parts schematic for a Bb400 gold tone bass banjo
This is a list of All the parts you need, I don't know about a schematic?
1 Maple Neck ? 1 11" wood rim ? 1 11" notched tension hoop ? 1 Flat head alloy tone ring (Optional bell brass available) ? 1 Resonator (not included in the open back kit) ? 1 11" Remo frosted banjo head ? 1 Arm Rest ? 2 Coordinator rods with hanger bolts (one longer than the other) ? 1 "L" shaped tailpiece bracket (may be attached to coordinator rods) ? 1 5th string nut ? 4 Guitar style tuners (planetary tuners optional) ? 1 Geared 5th string tuning machines ? 24 Shoe style lugs with bolts and washers ? 24 Hooks and nuts ? 1 Nut, pre notched ? 4 Resonator plates ? 4 Brass inserts (brass anchors that are threaded on the inside) ? 4 Resonator bolts (knurled on the outside with a Phillips screwdriver receiver on top) ? 1 5 string bridge ? 1 Gary Price style Tailpiece ? 1 Set of strings ? 22 Pre-cut (ready to install) frets ? 1 Truss rod cover (including three screws)
Mar 06, 2015 | Bass Music
Just got a Washburn B17 banjo. Where does the strap connect to?
Typically to the lugs, they rare the threaded hooked end metal pieces used to tighten the drum head.
Apr 09, 2014 | Washburn B17 5-String Banjo
I bought a used Fender FB55 banjo, it's appearance looks new. I'm new to banjo's but not guitars. I really didn't know how a banjo should sound. I practiced with it as is, I noticed that I...
Check the neck to body attachment. There may be a problem there, especially if it has been strained in the past. The fact that the strings were so high when you got this would indicate there MAY be a problem with the neck attachment or the body where it attaches. Word of caution: Investigate how repairs are done on the instrument before attempting a fix. Using wrong materials can permanently disable an instrument. Banjos DO go out of tune easily, depending on how they are played. Another thing to remember is that strings are within about 10% of breaking when in tune on stringed instruments.
Sep 10, 2011 | Fender FB55 5-String Banjo (Refurbished)
What would cause certain strings on my banjo to have a flat sound and not a ringing tone? These are a brand new set. thank you ...
The laws of physics govern this. The strings "ring" while they resonate. The time they resonate is related to the "Q" of the string or the efficiency. The Q is the enrgy stored divided by the energy lost per CYCLE of the oscilation. Strings that damp out quickly have a low "Q". This can be caused by any of several things thaat include anything that can dampen the oscillation. String quality is important as well as secure attachemnt at each end and proper placement in the nut at the head. See if you can find anything that creats drag INCLUDING string height that affects the windage as they vibrate. First place to look is at the resonator end. Are the strings well attached at the end? Is the bridge properly placed and setting tight on the head? The bridge often has offsetss for some strings... check that it is properly oriented. I will refer you to videos on banjo stringing on YouTube, They can cover much more than we can here using text.
Jul 15, 2011 | Washburn OB5 Oscar Schmidt 5 String Banjo...
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
Nov 03, 2009 | Washburn D10sbc Acoustic Guitar
Washburn B9 5-String Banjo Logo
Top Washburn Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
rhodesworks
Are you a Washburn Music Expert? Answer questions, earn points and help others
