Question about Uniden BCT7 Base Scanner
I tried to program the codes in and it isn't working. What am I doing wrong?
You need to have the instructions and follow them step by step EXACTLY. I was having the same problem when I first bought it.
Posted on Jul 20, 2012
    President:
  • 2,761 Answers
Without knowing what you're doing, it's difficult to tell what you're doing wrong, but the first step is to refer to "frequencies" - not "codes". You didn't mention whether or not you have the owner's manual for your scanner, but that's where the best programming instructions can be found. If you don't have the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BCT7om.pdf
You also need to make sure that you have the current frequencies for your area, and remember - your scanner will not work with trunking systems. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Posted on May 26, 2011
My 2007 Honda civic just had its battery replaced...So I've been trying to get my radio (and clock) to work again. The previous owner recorded a 5 digit code in the owner's manual. I've tried...
sometimes the code is put on the bottom of the ashtray just remove it and flip it upsidedown should be 4 or 5 digit number somewhere on it
Dec 09, 2012 | Cars & Trucks
My midland wr100 is going off for the wrong county, sometimes not for a county that isn't even programmed!!!
Press the menu button once until you see "TIME", press the up arrow until you see "SAME SET", press select, you should have "SINGLE" selected if you are only wanting to get alarms on one SAME code. Press "SELECT" the screen should go to SAME 01, press select again and confirm that you have the correct SAME code entered. "MULTIPLE" will allow for more than one SAME code to alert and "ANY" will set the unit off for any SAME code alert.
Oct 17, 2012 | Midland WR-100 Weather/RDS Radio
Chrysler sebring code p0513
P0513 stands for invalid SKIM Key. Basically it means that the "computer chip" that is in your ignition key which has a special code is not recognized by your vehcile compter (PCM). In most cases that I have come across is that either your VIN is not entered or is the incorrect VIN programmed into the PCM. Have you recently changed the PCM ? You may try another ignition key but I doubt that would work unless you are using the wrong key for the vehicle. You will need special diagnostic computer programs in order to correct this problem. Most likely your PCM will need to be "Flashed" to the VIN. This really isn't a weekend/backyard/part time mechanic fix. Hope this helps you to understand what the code is and what it means. Guessing the vehicle won't start.....
Oct 10, 2012 | 2004 Chrysler Sebring
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
I need the keyless entry programming code for my 01 Audi A4 Quattro 1.8T Note: Driverside lock doesn't work with regular key, and is the only lock on the entire car.
That isn't how it works, you must have the dealer reprogram the whole system to correct this if the loss of program is the cause. You can't do it at home it requires a special tool to go int the control modules programing option.
Sep 30, 2012 | Cars & Trucks
How do i unslide a HTC phone?
If the Hermes works in the same way as the wizard, the orientation switching is done with magnets (wave one over the screen and see)
What my (admittedly non programming and possibly very wrong) brain tells me is that as there isn't an 'app' that swithches the screen, there wouldn't be anything for you to modify
Although it is possible I'm hopelessly wrong!
Sep 06, 2011 | HTC Desire Cell Phone
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
Presario C714NR gr983UA#ABA ALPS touchpad does not work I have updated the BIOS and uninstalled and reinstalled the drivers but it still does not work
I had a similar issue with my ASUS. Try finding a program on your computer other than the Control Panel that controls the trackpad. For instance mine is Elan Smart-Pad. Usually working with some of the configurations in the program reinitialize the trackpad. If that doesn't work make sure that it isn't turned of due to keyboard interference (hitting a button that turns the trackpad off). Hopefully that isn't the case though.
May 10, 2011 | Compaq Presario 700 470024-192 Notebook
I have the Vigoro (196-036)/Melnor water timer. I bought it last year to replace a different model. I replaced the battery and set the program this year, but the program isn't working. I can use it...
At the
Bottom right there is a button to turn the program on and off. Make sure you have it on. I think a black little
Bar shows if it is on.
May 07, 2011 | Garden
Uniden BCT7 Base Scanner Logo
149 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
