Question about The First Years miPump Single Pump
My single mi pump somehow started sucking milk into the tube. Not sure why/how this happened. I tried to rinse and dry it all out and now the pump doesn't suction enough to pump
My jura X7 system is rinsing with milk. When pressing the rinse button, the machine is drawing milk to rinse instead of water??
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
Aug 15, 2013 | Jura Capresso Impressa X7 Espresso Machine
Miele built in. Steam but no froth
Sounds like the venturi tube could be blocked. My model is a CVA 4085 and I can take the assembly out that sucks in the milk, mixes the air and stem and spits out frothed milk. If yours is similar, see if you can can reach the top of the milk outlet tube and rotate the ring around it anti-clockwise (if you were looking up from the bottom) and take the whole assembly out. If you have never taken this out, disassembled it and rinsed everything out thoroughly under a running tap now is a good time to do it. Then check the venturi tube: the clear (ish) bendy plastic tube that that points up and has a cone with a hole in the top. If that hole is blocked you won't get very good froth. If you can't clear it with warm running water then VERY CAREFULLY use a small needle to push through the hole at the top, then put everything back together.
Good luck.
Jan 14, 2013 | Miele Coffee System
Miele CVA 4066 stopped frothing milk
It sounds like the venturi tube is blocked. Have you ever removed the frothing unit and cleaned in manually? I have a model 4085 and I can reach under where the milk exit tube comes out, twist anti-clockwise (if you are looking up at it) and the whole assembly with the inlet and outlet tube comes out. These pieces can then be individually taken apart and rinsed thoroughly with warm water. If you put it back together (don't forget to twist the connector that locks it back in) and the milk still doesn't froth, take it out again and use a small needle to clear the top of the clear venturi tube which sucks air in to do the frothing. If it is really badly gunged up it might need to be replaced, but mine is 5 years old and still going with regular rinsing. My whole brew unit had to be replaced after 4 years at a cost of about GBP 200, but that's another story.
Nov 21, 2012 | Miele Coffee Makers & Espresso Machines
Froth dispenser problem
Good luck.
Oct 24, 2012 | Miele Coffee System
Milk does not froth
Good luck.
Oct 22, 2012 | Miele CVA4070 Coffee Maker
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have a Saeco Royal Professional. My problem is that the cappucinatore is not sucking up the milk. We've rinsed it with water and it still doesn't **** up the milk.
HI
If you still have the pin in the top of the cappuccinator, try twisting it when the cap. is steaming. Twist slowly until it starts to draw milk up the tube. If you don't have the pin that is the problem.
There is a flat side on the shaft of the pin that causes the suction when the steam passes the pin. If you don't have the pin you can get any suction.
Dec 31, 2010 | Saeco Royal Professional Espresso Machine
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Dawn in the Jet Dry Dispenser
It may not hurt the machine, but it leaves soap on the clean dishes. You can't really remove the reservoir without dismantling the entire door. it's pretty straightforward, but takes a little time and effort. If you're not prepared to dismantle the door to get to the reservoir, you -could- try cleaning/rinsing it out with a turkey baster and a small diameter piece of plastic tubing. Just suck everything out, then fill it with rinse water and suck that out as well. But you'd have to fill it with rinse water over a dozen times to really get it clean. Hope that helps. ;)
Aug 09, 2007 | GE 24 in. GSD5560GSS Built-In Dishwasher
The First Years miPump Single Pump Logo
309 people viewed this question
Top The First Years Baby Care Experts
Tom Chichester
masud
masud
Are you a The First Years Baby Care Expert? Answer questions, earn points and help others
