Question about HP Office Equipment & Supplies
Printer is not registering new cartridge, which is full and an HP "02" . Printer was out of cyan blue for a while, printing in black and white, then replaced it. Ink is flowing, checked with toothpick, printer not sensing ink flow, or flow being interrupted? Thanks, Mindy C
    Guru:
  • 352 Answers
Hello.
New cartridges that are not HP brand can sometimes give these errors. If they are HP brand then the issue is with the sensor that reads the cartridges "chip" The ink levels are not read like the fuel in your car, there is a page counter on the cartridge and when it hits 0 then it assumes there is no ink. So the issue seems to be it is not reading the chip correctly. Try removing all the cartridges. turn the printer off for 10 mins and replace the cartridges 1 by 1. This can sometimes correct the issue. If not the pins that read the cartridges chip can be checked for dirt of dry ink that may be interfering with the pins touching the cartridge. these pins are in the Cartridge holder for each colour, inside the printer. use a torch to see them properly.
Good Luck. Regards GM
Posted on May 26, 2011
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Mar 13, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
I had bought my printer at UAE and now i am here in Philippines but the cartridges compatible here is Hp74/75, when i inserted it "both printer cartridges are not intended for the use of this...
Hi ,
The compatible cartridge for this printer is as follows :-
1. HP 02 I C8721WC black
2. HP 02 C8773WC yellow
3.HP 02 C8771WC Cyan
4.HP 02 I C8772WC magenta
So got any HP service center and ask for above no cartridges
Nov 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
