There are many possible answers, but the best way I've found and for all types of mowers is:
Put the mower on a level garage floor or pavement area. Rise the mower deck to the highest level. By hand (everything off, of course), position both blade tips to the furthest outside edge of the mower deck (widest from tip to tip). Use two wood blocks or equivalent sized objects and place them under the blade tips. Find something that comes very close to the blade but doesn't touch. This is so you can see a gap for reference sake. Adjust the linkages (usually long links, from front of tractor) until the spacing is the same between both blade tips and the objects under them.
The manual has you measuring the blade tips. I find blocks or spacers easier... http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf - see page 17
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
