Question about Eagle FishEasy 245 DS 4Inch Fishfinder ()
I have a blank screen on my finder. the buttons make noise.the back light works but no display. the unit has power. The transducer is properly mounted and has worked previously.
4 Suggested Answers
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Posted on Jul 21, 2009
SOURCE: A light comes on in the lower bottom of the
Be sure you turn the contrast down. We had ours up high and we couldn't read anything. I brought the contrast down and we could read it even in bright sunlight.
Posted on Aug 24, 2010
paul4265
  • 592 Answers
SOURCE: I am replacing a Eagle Intellimap gps and eagle
Hi, Charlie!
I checked it out, and it turns out you can use the transducer of off your old 128 model.
Just unplug it from your current model, and plug it back into your EFE 480.
What I like about these newer fish finders is the fact that it also has gps built in to it, along with the maps for all of the USA, and the fact that it has a memory card slot, so that you can download new maps onto a memory card, pop it into the machine, and then it will update the maps !
Sure beats the old days where you had to send the unit in to a tech to have them install map updates.
Som yes, you can use the old one, and it should work with no problems.
Good luck to ya, and catch a big one for me !
Posted on Feb 14, 2011
I turn on the finder and i get a bunch of doted lines like mores code, This is in or out of the water,Is this the unit or the transducer
Hi Bill
It sounds very much to me like a cabling problem. I'd try cleaning all connections with silicone spray (safe for plastics) and give it another try. If you let me know the make of your finder, I'll certainly give it my best shot to help you out.
Good Luck
-Steve
Jan 15, 2015 | Boating
PC will not boot up when power button is turned on. Screen remains blank (off). Noticed PC resesting (turn off and than back on) every minute or so, (can tell this by lights on power button and internal...
connect your laptop to an external monitor using a VGA cable to see if its display. if not, open the PC to check if the memory is properly working, if not, replace it. if the problem continue, check the system processor.
Sep 25, 2010 | Compaq Presario 700 470024-192 Notebook
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
The plug going into the back of my Eagle 350c got hot and partially melted. It still works now but for how long I don't know. Can I splice a new plug in or do I have to buy a whole new transducer?
Well, if it is still working ok now with the partially melted plug, then the transducer itself sounds like it is fine... Attach a new plug and it should all work the same (just with a nice new plug).
Also make sure your power supply to the Fish Finder is properly fused.
Feb 07, 2010 | Eagle Fishelite 502c Igps Fish Finder...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Lowrance x135 not functioning properly
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Lowarance fish finder
Firstly check you connections to your battery or any switches in line are secure and not corroded or damaged. If there are any loose connections then this could possibly be a reason, although unlikely, but its good to check those first anyway.
Next make sure the transducer/power cord is inserted fully into the back of the display unit. Again check for corrosion and good connection here.
The most likely porblem however is a sticky power button. If these are not freely engaging and retracting when pushed, the switch could be arcing causing the unit to turn itself on and off intermittently. You either need to pull the display unit apart and try to remedy the problem (if it is out of warranty and you are happy to do that yourself) or get a professional technician or Lowrance service centre (if still under warranty) to attempt the fix.
Mar 16, 2009 | Boating
Eagle FishEasy 245 DS 4Inch Fishfinder () Logo
57 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
