Question about Mad Catz Call of Duty Black Ops PrecisionAIM Controller
Hi I can't seem to get the controller to vibrate and my ps3 is saying the vibration is on but I don't feel it working
  • 2,404 Answers
Try another controller that you know the vibration is working properly. If it works then you know the original controller is faulty. Those wireless controllers have a little motor that vibrates and they can go bad after alot of use, or if they get thrown around, etc.
Posted on May 26, 2011
My core controller just vibrates
Hi
The problem may be with the game. some PS2 games are partially compatible with PS3.
When the controller vibrates and turns off use the wire to switch it on and keep running.
Jul 02, 2013 | Nyko Raven Motion Sensing Wireless...
1998 harley flht 1340 carberated, vibration problem from 1300 to 1900 rpm
Hi James, and the usual suspects are:
1. Wheels and or tires unbalanced, worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain badly worn or links tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect/poorly tuned engine
7. Internal engine problem/ flywheel shift runout should be .003" max.
8. Broken frame
Good luck and have nice day.
Sep 04, 2012 | Harley Davidson FLHT Electra Glide...
Chevy uplander traction control seems to be working all the time
Can you feel the vibration through the steering wheel if so have your front discs machined & the front pads replaced. Or are you feeling the vibration through the pedal? if so it may be the rear but start with the front.
Jul 15, 2012 | 2005 Chevrolet Uplander
Hi, You assisted me before on the same vehicle. I installed my new transmission system and have been driving it for a couple of month now. The issue is a Vibration when I first release the clutch in 1st...
The last time I felt vibration in the pedal like that I had a broken clutch finger. I would hate to tell you to take it all out again only to find no broken fingers. I've also seen vibration from improper mating of the friction disc and flywheel. It'll wear on the inside of the flywheel before it wears on the outside and thus you feel that as a vibration. But, it is most likely the clutch plate isn't balanced right. Just to be sure, take a look at the harmonic balancer to make sure it is still one piece and the rubber isn't coming out. It can dampen out most vibrations like this but can only do so much. But, if it is compromised in some way, even small vibrations can get through. Also, did you install a new pilot bushing when you did the clutch? Fixya is discontinuing this service soon and they say they have plans to come up with something new. I'm not supposed to share contact information here per terms of service, but there is no reason you can't Google 'ZX2Fast' now is there? If you need more help and can't get to me from here, just Google me and I'm sure you can find some way of asking for help. Oh yeah, you should also inspect all of your engine and transmission mounts. You would feel vibration if you have a broken mount and the engine/transmission was resting against metal.
Feb 11, 2012 | Cars & Trucks
How do I turn the ringtone volume up? i set the ring setting to "vibrate and ring" and when I get a call from someone I sometimes feel the vibration but I don't usually hear my ringtone...how...
Hello patty,
Depending on the brand and model of your phone, there usually is a volume control on the side of your cellphone. If it doesn't have one, please reply here and indicate the brand and model of your phone.
Oct 16, 2011 | Cell Phones
Buick lesabre starts vibrating at 45 mph and stops around 55 mph...the steering wheel does not shake much but you can feel it vibrating just the same.....had new tires put on and balanced for the 2nd...
A vibration such as you are talking about could be caused by more then one thing. First it could be caused by a broken belt in one of your tires. I could also be caused by a bent rim, a warped rotter, or a bad cv joint. I hope this helps you solve your problem.
Aug 31, 2011 | 2003 Buick LeSabre
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you sitek.com itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
CECHZC1E -Wireless Controller
the standard Sonuy cotroller does not have vibration.
There is a new one on the market (can't recall the name right now also made by sony). Runs about 75 dollars.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
Vibration on Logitech Wireless Xbox (not 360) Controller
when you play a game go in option menu you will see vibration on off press on the button and you should feel vibration cheers
Jan 17, 2008 | Logitech - Cordless Game Controller...
Mad Catz Call of Duty Black Ops PrecisionAIM Controller Logo
133 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
William Wurtinger
John mullen
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
