Question about Makita 7" 9227c Buffer Polisher Sander Kit 9227cx3
Hi ! My unit do not turn to its right rpm, erratic power.
  • 2,176 Answers
Could be a couple things. UNPLUG tool and remove one handle half and see if it is jammed up with lambswool from the bonnet. It can get under the brushes causing the erratic power. If thoroughly clean the entire motor housing and then remove and check the brushes for wear. Let me know if you need more assistance.
Posted on May 26, 2011
Unstable RPM and not sure what's the cause of it.
Has to be something in the fuel delivery system. The more fuel you give the engine the faster it turns and vice versa so it has to be something in this area. Could the fuel pump be operating erratically and have erratic pressure - that could be it.
Aug 30, 2015 | Cars & Trucks
Oil pressure is 32 while idling and goes up when RPM INCREASES
Hi Anonymous, normal oil pressure is 32-38 with engine hot and running at 2,000 RPM. If you are getting erratic readings you could have a bad sending unit or gauge. Good luck
Apr 19, 2014 | Harley Davidson FLHTCUI Electra Glide...
Hi I have a 92 bronco engine light goes on and off when on no power to trans runs ruff erratic rpm when I turn truck off and cycle key to acc I hear fuel pump click on then off but I here something...
ya it could be but also you could have wires touching when the motor starts and when you shut off the motor the wires disconnect i worked on a bronco with the exact same problem
Jan 28, 2013 | Cars & Trucks
I have a 1997 Grand vitara V6 2 Litre The check engine light has been coming on intermittently for some time but has been okay.As of yesterday the engine RPM at idle has been very erratic rising and...
Hello and welcome to FixYa!
If the check engine light is on then there's definitely a problem. The engine rpm is erratic right? This can be caused by a faulty MAF (mass air flow) sensor. If the MAF sensor is faulty the idle will surely be erratic and may cause stalling.
You will need to have it replaced to make the vehicle back to it's normal operation again.
Hope this helps and thank you for using FixYa! Have a good one!
May 01, 2011 | 2000 Suzuki Vitara
My 1997 Chrysler Concord idles at 2500 to 3000 rpm when first started and when it warms a little it idles at 2000 rpm and stays there. When I start it right after I turn it off, it starts at 2500 rpm then...
Maybe a short to the TPS or something shorting it out. There's also the IAC that really controls the idle but usually it will cause the RPM's to go up and down a little erratic if bad. The MAF sensor can cause major problems as well but since you already swapped the TPS and it helped and then stopped I would focus on that sensor and especially it's wiring to and from the ECM. Be careful with the sensor signal wire to the ECM can blow it if more than 5v passes or spikes.
Sep 03, 2010 | 1997 Chrysler Concorde
Rough eratic idling
Check the idle air bypass valve see if dirty, cleanable unit. you check the working of valve by powering the unit with 12 volts. check map sensor too.
Nov 14, 2009 | 1990 Ford F150
Engine idling rpm is erratic when cold. low power during startup. fuel mixture is very rich.
ajust your mixture screw on your carb turn it in fully then unturn two and half turns that should get your mixture ok you mat need to fine ajust later
Nov 11, 2009 | 1996 Mitsubishi Eclipse
RPM's are jumping around at high speeds
Sounds like you may have a bad ground somewhere or a bad power connection.
Sep 14, 2009 | 1993 Honda Accord
97 NZ new, Nissan Sentra Q with erratic RPM indication.
do you mean the speedometer or the engine RPM ----gearbox??? if its the engine RPM their is no sensor as it reads from the ECU unit which is controling the engine management
Mar 14, 2009 | 1998 Nissan Sentra
95 honda accord v6 tach erratic and sometimes zero accompanied with minor power flucuations.
Hi ....
On your HOnda accord V6.
The rpm is generated from the Distributor.
The more possible problem for erratic RPM is the cam sensor inside of the Distributor. But I guess you can't buy just the sensor.
And can afect the engine performance.
OK. I hope this information work for you.
I work on cars everyday. Thank you for use fixya.
Jul 17, 2008 | 1994 Honda Accord
Makita 7" 9227c Buffer Polisher Sander Kit 9227cx3 Logo
143 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
