Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have connected a Roku Digital Media Player to Sharp AQUOS TV, I am able to get the video but no audio from TV, Audio cable and all are setup properly. Can anyone suggest me? also i see the same problem when i connect a Laptop to TV using HDMI cable
  • Sharp Master
  • 10,291 Answers
Use the HDMI cable on the Roku. The reason you don't have audio from the laptop is because the HDMI out on the laptop has no audio on it. You need to use a 3.5 mm audio cable to connect the laptop audio to the TV.
Posted on Dec 31, 2014
tvtek
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Posted on Jun 02, 2009
  • 8457 Answers
SOURCE: Sharp aquos LC-42D62U. Have audio but no picture.
Ur LCD inverter is dead,must replaced to get the picture back.
Posted on Dec 02, 2009
SOURCE: trying to hook my roku box to my sharp aquos 46 in using my hdmi
according to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
Posted on Jan 07, 2010
I have sound but no picture
Check your connections between your Roku box and your TV more than likely you have the audio cables plugged into the wrong jacks, Using a single HDMI cable would eliminate this issue if you have an available HDMI input on your TV. Notice which jacks are the audio output jacks on this pic, make sure these are connected to the input on your TV, the ONLY time you don't use these jacks id if you are using the HDMI connection, they are REQUIRED for composite video, component video (high def color) and S-video.
May 25, 2015 | Roku XD Streaming Player 1080P Wireless-N...
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
I need to add a code to activate my roku
First create a Roku account here: Welcome to your Roku account
Then you can Link your Roku device to that account with the link code displayed on you TV screen, from your Roku device: Roku Link Device
Dec 15, 2014 | Roku 3
How do i get my roku to work on sharp aquos?
The Roku is an external media player designed to function with all TVs. Depending on the model of Roku you have you need to conext the video out whether it be RCA (the yellow red whit cables) or HDMI into the corresponding input on your sharp TV then with your remote or the input button located on the side of the TV you need to change the TVs input to the the same input you plugged your Roku into.
Jul 22, 2014 | Sharp Aquos Televison & Video
Sharp aquos lc-32le600E connected to PC video is fine, but no audio, any advice? Thank you in advance
Good job---Thank You for letting us know you got it and thanks for using FIXYA.
Mar 15, 2012 | Televison & Video
I have a Sharp Aquos. A video cable is connected to interface EXT-4. Video is working fine. Which audio interface can |I use to get audio too and what do I have to set in the TV menu?
There should be RCA type audio input connections near the ext-4 video cable. One red and one white. If you connect these cables you won't have to do anything in the menu.
Aug 30, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
156 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
