Question about Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television
Hi, I have a TH-42PWD8 MONITOR that I bought from the plant i worked at in an auction. There is no remote. I had it connected to my laptop once and it worked fine. I want to connect a DVD player to it. What jacks do i need? How do I connect them? Can I get the monitor to work without the remote? And if I wanted to run the monitor as a TV, what all is involved with making this happen? I really need and would appreciate your help, since i can't return it...nor do I really want to resell it.
  • 35 Answers
SOURCE: TH-42PZ77U Blinks 10 times (worked fine for 1 year)
The P, PA, DH, H or DT board may be defective. Email for some help...
Best regards
gysgt2u1@yahoo
Posted on May 08, 2009
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
keiffertech
  • 96 Answers
SOURCE: Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
Posted on Sep 03, 2009
tvservice306
  • 458 Answers
SOURCE: My Panasonic TH-42PX60U Plasma tv will not respond
need panasonic remote
Manufacturer Panasonic Part Number EUR7737Z20 Description REMOTE CONTROL
Posted on Nov 09, 2009
nileshsingh2
  • 246 Answers
SOURCE: I bought a Panasonic 42
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
Posted on May 15, 2010
HPC Monitor won't change input
Try a replacement remote control. A good one is a Philips Universal which can be found at Walmart or Right-aid. Around $14 bucks, and is very modern and up to date for just about all flat panel sets. (It's also a learning remote, so it will learn remotes).
Feb 02, 2014 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Tip
How to connect laptop to TV Panasonic TH-42PX50U
Hi,<br />i have TV Panasonic TH-42PX50U, but i don`t know how to connect it with laptop...<br /><span><span>Can I</span> <span>do it</span><span>?<br />because i bought cable and it doesn't works, when i connect they then on laptop is signal, but nothing happens on TV and laptop more... </span></span><span><span>I</span> <span>open the</span> <span>laptop</span> <span>program</span> <span>but</span> <span>there's</span> <span>no evidence to show... <br /><br />i hope somebody can help me!<br /></span></span>
on Dec 18, 2010 | Panasonic TCL42D2 42 in HDTVReady LCD TV
How to use external monitor on a toshiba laptop with external monitor
It's probably best to buy a keyboard off auction sites or a new screen, the Function keys are not OS sensitive so a different keyboard will not work with them, they are device specific and require special drivers to operate.
Are keys broken or are they just missing? the membrane will still work to a firm press even if the key is missing.
keyboards can be found on auction sites
sorry I can't help more.
Apr 25, 2012 | Toshiba Computers & Internet
I have a panasonic plasma TH-42PWD8 bought one 2 years ago but did not use it. Now i fixed it and started watching and then after one hour suddenly i see that the screen goes blank and the LED light to...
The factory diagnostic for an 8 blink error code is: Driver SOS 3 SS-Board / SS2-Board; SS FPC Detect; SS Energy Recovery Circuit. Basically it means that the current absorbed by the X-Sus board is too high. It looks like this
http://www.discount-merchant.com/PANASONIC-TNPA3544-X-Sustain-Z-Sustain-Board-p/1042654.htm
You will need to open the tv and check the connections to this board and all the components on it. Also check the filtering capacitors from the power output line that powers this board.
If you can't find anything wrong then the entire board will have to be replaced.
Aug 06, 2011 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
May 15, 2010 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Pana TH-52PWD8UK. No picture, flashing red LED on front panel
Thanks for the quick answer. I purchased the set in 2005 and it lives outside under an overhang on my patio in humid South Florida. Unfortunately, I couldnt count the red flashes before it went completely dead. Think it was 4or 5. This would correspond with a possible fuse failure on the Power supply. I bought the online service manual, I just wish I knew what to do with it!! The fuses both seem to check out ok on a continuity check. any ideas? Thanks, Charlie
Dec 05, 2009 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Dad Bought 2 NET-TV's Model DTV34X,from school auction. NO REMOTE
hello,
sorry i don't help you . plz don't mind every man is not perfect.
bye
ramesh722
Nov 13, 2008 | NetTV DTV 34XR 34" CRT Monitor
Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
