Question about Kenmore HE2 Plus Front Load Washer
This front loading washer sounds like a jet taking off during the spin cycle. It has done it from the first time it ran, so we've just assumed this is the price to pay for clothes that are practically dry when you take them out of the washer. Is this normal for the Kenmore front loaders? If not, how can we quiet it down?
    Scholar:
  • 142 Answers
This washer should make very little noise in spin. Check if there is something, like a nail, stuck in one of the holes in the spin basket. What does happen with these machines is that the support that holds the spin basket (which is behing the rear wall) breaks. But that only happens after using it for a number of years. See if you can move the spin basket up or down, or sideways when at rest. If you can, you would need a new spin basket.
Posted on May 26, 2011
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
My washer is very loud when it is in the spin cycle.
if the machine is more than five years old or it gets a lot of use it sounds like the drum bearings are starting to wear. If it sounds like a jet taking off when it begins to spin then thats your problem. Basically bearings have seals which over time and use will eventually allow water in and the bearings will start to wear. Now is the time to get the bearings done before they seize. It can be a laborious and expensive job
May 24, 2010 | Kenmore 43042 Front Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
104 people viewed this question
fordexpert
Mike Squire
Robert Rankin
