Question about LG LP0910WNR Air Conditioner
Hi my lg lp0910wnr is not turning on I plug it into the outlet on the wall the little green light on the plug is on but whe I hit the power button on the unit it won't go on pleas help me out.
tvtek
  • 1284 Answers
SOURCE: LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Posted on Nov 30, 2007
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
SOURCE: my lg tv (model number 42LH40) won't turn on
There might be an off on switch under the lower right hand corner of the set. (feel for it) and switch it.
Posted on Feb 13, 2010
  • 7 Answers
SOURCE: My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Posted on Mar 28, 2010
  • 4736 Answers
SOURCE: my LG portable AC won't
I have searched all LG data bases for the Model Number(s) you listed and those numbers were not found.
Please recheck the model number and get back to me. So that I can try to help you, again.
Thanks, Rich
Posted on Jun 10, 2011
I hav icraig slimbook model CLP288 red light that indicates its chargeing comes on but I push power button green light very brief comes on then off screen never comes on .plz help
Try plugging the charger into a wall outlet if you are currently plugging it in a power strip. If you are not try plugging it in another wall outlet. If that doesn't work you can try a hard reboot if the battery is accessible. To do this turn off the slimbook, unplug it, take out the battery and hold the power button down for 30 seconds. Once done put the battery back in, plug it back in and turn the slimbook back on.
For other IT soultions try visiting: https://www.youtube.com/user/jrlake2414?sub_confirmation=1
Jan 24, 2016 | Computers & Internet
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
The lexmark x5450 printer will not power up. The power source (black box ) is putting out 30 volts when pluged in and the little green light on the power box is on.Now what?
Great job on checking the little green light on the printer's power adapter. Just make sure the printer is plugged in straight to the power outlet in the wall, bypass any surge device or power strip as they tend to draw away power. Make sure to plug the power adapter in the correct position and properly secure it behind the printer. If it won't automatically turn on, press the power button on the operator panel.If problem persists, printer may have hardware problem. I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 22, 2010 | Lexmark X5450 All-In-One InkJet Printer
While I am watching TV on my Sony kdf-60xs955, the screen goes blank and the green light just flashes. Sometimes it comes back on and sometimes not. I hit the power button and the red light flashes 5...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Check by changing the Power cable to any other wall outlet in your home
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Mar 16, 2009 | HP Pavilion a450n PC Desktop
I have a emachine model t3958
try to reseat the power cable of the computer and power it on again
Jun 24, 2008 | E-Machines eMachines Desktop PC
LG LP0910WNR Air Conditioner Logo
173 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
