I hit some random buttons on my sears t.v and now I only get 13 channels, i've fixed it before but i can't remember how to fix it again! please help!
    President:
  • 2,080 Answers
Go into your TV's MENU and go to the CHANNEL SETUP options.
Make sure that your CABLE option is set to ON.
Good luck.
Posted on May 26, 2011
Lost channles
Look in main menu, set is now in the air band which is 2-13 and you want it in the catv or cable band.
Aug 27, 2012 | Orion1934 19" TV
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Power comes on - screen says NO SIGNAL. Have already checked cable line with another TV and it works fine. Have we hit something on the remote that has put it into that mode?
The only reason your TV would say "no signal" is that it's searching an input for a signal and not finding it. That being said, Yes, You've probably hit the "input" button on your remote. Easily fixed by selecting a different input or changing the channel on the television.
May 03, 2011 | Televison & Video
My 96 year old Mother-in-law has a Sears (SR) Model 580 television. We cannot figure out how to get it to Channel 3 so as to hook up a new Federally Sponsored reception box. There is a panel for...
Those adjustments were marked with letters so you could set ant position to any channel, and the channel know was marked A-L as well. The set came with labels you could put into the knob with the numbers.
Associated with each of those adjustment screws should be a small switch, labeled (if I remember correctly...I was a Sears TV tech over 10 years ago and haven't seen one of these sets since then!) VL, VH and UHF. VL is for channels 2-6, VH 7-13 and UHF 14 up. There might also be a little indicator window showing how far up the band you've gone. There may also be a switch marked AFT on/off. If you have that, turn it off to set the tuning and turn it back on when you're done. Put the switch on VL and turn the adjustment until you're tuned to channel 3. You'll know when since you'll see the programming.
I hope I haven't been totally off base. Like I said it's been a while. If this has helped, please feel free to give this solution a good rating. (If not, please feel free to pretend this never happened!)
Apr 21, 2009 | Televison & Video
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
