Question about Lightolier Controls Lm2 2000 Dual Universal Dimmer Mod
The power coming the the relay for the out side lights has 30 volts AC and it should have none
    Problem Solver:
  • 18 Answers
Not sure what you mean, power from relay? Make sure when you test for power you test to ground as well as the neutral wire. In some cases power is detected on the neutral from a back feed.
Posted on May 27, 2011
I need a wiring diagram for a 2000 Toyota Echo A/C compressor clutch.
relays work y having two circuits
one circuit comes from the triggering device, switch , climate control module ,thermostat which supplies 12 volts to a internal coil then out to ground
When that is achieved the coil closes a set of points
The second circuit is the high current circuit which allows the heavy current draw to pass through the points on to what ever it powers ( AC clutch in this case
If the points are not closing , then either the coil is faulty or the ground wire is not completing the circuit
Jul 01, 2018 | Toyota Cars & Trucks
Need a/c wiring schematic for 2007 peterbilt 386
First is there power at the CONNECTOR to the clutch? unplug it and run the vehicle, with a Volt meter, ground the black lead, and check the pins on the connector for voltage with the AC controls set to ON. if there is 12-14 volts on one pin re check with the control set to off. if the voltage goes away at the connector, it is a switched POWER system, and everything is fine with the controls and you found the correct power lead. NEXT set the meter to OHMS and test the connector again with one lead grounded and (DO NOT TOUCH THE POWER PIN or pins, which is why you check for power first) and look for the one that grounds the circuit. then to identify function, connect a 12 volt light between the +12 pin and the ground pin. the light should illuminate with your AC controls. this sounds like you misread your AC relay, and this will identify that error 100%, OR you have corroded connections on the pins directly, pulling the connector off the clutch will make this painfully obvious. any good electrical connector cleaner will work along with a tooth brush to clean this
Jul 05, 2014 | Vehicle Parts & Accessories
Dodge 1500 1995 pickup 7.5 volts to fuel pumpwill not start applied 12 volts pump runs book sayes pcm de-energize booth relayes and will not send proper voltage to fuel pump
There is a red and white wire feeding the fuel pump relay from a 30 amp fuse. Both the shutdown relay and the fuel pump relay are grounded by the PCM, so if the fuel pump relay is grounded it should be "on" and providing a direct link from the pump to that fuse.
You should have battery voltage on that 30 amp wire before the relay and then on the dark green and black wire going to the pump.
If you don't have battery voltage coming from the 30 amp fuse, the problem could be before the fuse.
That 30 amp fuse is hot all the time, so it is powered by a fuseable link coming off the battery.
Jun 24, 2012 | Cars & Trucks
Ford explorer Power seat will not move
Check the voltage from the cpu,if there is none,replace the cpu again.Hold seat to foward for 12 seconds then release,wait 20 seconds,see if it will reset.If not replace the cpu
Apr 04, 2010 | Ford Explorer Cars & Trucks
My HP photosmart 2710 will not turn on. There is 31 volts going into it??
Option 1
If you have a blinking light try changing cart.
Option 2
If the unit is blackout change the power supply. Here are the specs
Power specifications
* Power consumption: 75 W maximum
* Input voltage: AC 100 to 240 volts - 2 A 50-60Hz, grounded
* Output voltage: DC 31 volts === 2420 mA
Sep 16, 2009 | Computers & Internet
Roof a/c unit clicks when wall thermostat is adjusted but wont come on?
no ac power you are hearing a 12 volt relay tellling it to come on but there is either no ac power or control ac relay is bad and you will have to replace control unit to ac useually arond 150 depening on unit
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac problem
Static pressure(Non operating) usually is around 70 lbs and should be even on both sides. Sounds like the systen is too low for the computer to allow operation. I suspect a small leak somewhere. Adding as little as 1/2 lb should allow operation and leak testing.
Jun 19, 2009 | 2000 Chevrolet S-10
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
Compressor Magnetic Clutch - 1996 Honda Accord EX
looks like fuse # 8 "heater control relay- ac clutch relay-cooling fan" fuse runs the 12 volt side " black and yellow stripe wire " pcm or ecm runs the ground side "red -blue stripe wire"- what else do you need?
Jul 31, 2008 | 1996 Honda Accord
Lightolier Controls Lm2 2000 Dual Universal Dimmer Mod Logo
73 people viewed this question
Top Lightolier Electrical Supplies Experts
Steve
robert
Tom Chichester
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
