Question about Wolfgang Puck Stand Mixer
I have the 700 watt Cafe Collection model CMSD0020. The head of the mixer will not stay down. The screws are both stripped and no longer fit into the screw holes. It is totally unusable. It doesn't get used all that much and is far too new to have this type of a problem. Please help me get this repaired. Joy
  • Alan Strobel May 26, 2011
    How long have you had this item, and where was it purchased?
4 Suggested Answers
defrankond
  • 65 Answers
SOURCE: kitchen aid mixer
the unit sounds like the drive unit is stripped. if the planitary unit is spinning that gear is ok but the one below that is stripped. which is the one that spins the beater. Usually the professional lines are covered under a 2 year warranty. where as the others are a 1 year. I would contact kitchenaid first and see if your product is covered for replacement. they are really good about replacing faulty units. if not the unit can be repaired. It is a simple process and you can buy the parts off kitchenaid. usually the parts come with instructions as to how to replace them but if not repost to me and ill get you the directions on how to replace it.
Posted on May 09, 2008
SOURCE: Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Posted on Dec 22, 2008
  • 1739 Answers
SOURCE: Where can I get like
Replacement parts for Wolfgang Puck Stand Mixers are available here:
http://www.wpcookware.com/categories.asp?cat=32
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
I need the wire whisk for a wolfgang puck mixer model CMSD0020
You will need to contact the maker of the appliance. We have no parts books here. Sorry
May 19, 2016 | Wolfgang Puck Stand Mixer
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Cooks model sm 248 mixing parts and break down on parts along with owners manual or opereting manual
i have searched the web and cannot find a instructions Manual for the Cooks mixer Model sm248... any help?
Nov 13, 2011 | Cook's Essentials 700 Watts CESM100 Pro...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
I have a KitchenAid Artisan stand mixer (325 watts/model KSM150), about 5 years old. Lately, when mixing dough for bread or cookies, the motor head of the machine wobbles a bit from side to side. In...
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Feb 20, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Wolfgang Puck Stand Mixer Logo
208 people viewed this question
Top Wolfgang Puck Food Mixers Experts
Barry Vista
Level 1 Expert
Lawrence Oravetz
Are you a Wolfgang Puck Food Mixer Expert? Answer questions, earn points and help others
