Question about Echo Garden
The cutters wont move anymore, the bar wont move, starts and runs
    Guru:
  • 1,833 Answers
Make sure blades are sharpened. If there are burs on bladesthey can seize. Blades should be lubricated with WD40, waste oil or otherlubricant. The bolts holding the two blades together shouldn't be too tight.
Posted on May 26, 2011
How to take chain off poluan pro saw
Before putting your hands near saw chain cutters, put leather gloves on. Cutters sitting still can still draw some blood.
Loosen the nuts holding the clutch cover, loosen the adjuster, then remove the nuts. Remove the cover. Slide the bar along the studs, free of the adjuster, toward the clutch. Revove the chain from the bar groove, then move it clear of the clutch drive. It's now off. Good time to clean bar grooves and bar-mounting area of dirt & chips.
Reverse the procedure to install a chain, making sure the cutters have their cutting edge facing forward on the top of the bar. Make sure the adjuster is engaged with the bar before tightening the nuts at all.
Holding the bar nose up, tighten the adjuster until the chain touches the bar on the lower side. Tighten nuts.
After short run to clear any debris, recheck the chain tension.
Jan 29, 2014 | Poulan Pro Chain Saw 46cc 20"
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Riso rz 220 the code A17 209 continues to come up
Hello
Yor cutter unit is not in the home position.
Open the front door, take out the master unit, remove the master material, lift the green handle and look to see if you can see a white plastic knob (that is the cutter) make sure it is to the front of the machine, if its to the back of the machine very carefully move it forward until it wont move anymore.
If it is in the front of the machine then the microswitch is probabally faulty and will have to replace the cutter unit.
Regards
May 18, 2011 | Riso RZ220 Duplicator
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
Riso RZ200EP WITH ERRO CODE A17-209 HOW CAN I CLEAR THIS?
take out the master roll look under the green plate you will see a white plasic knob, at the moment it is to the back of the machine that is the cutter unit, very carefully move it to the front of the machine until it wont move anymore. dont forget to switch off the machine, refit the master roll the problem should be resolved
Feb 20, 2011 | Riso RZ220 Duplicator
My motor is working but the top cutter will not move, I've taken it apart but it still wont move the cutter at all. The only time the motor moves the top cutter is when I unscrew it. What should I do?
The front tension is too tight loosen it a bit this may help, if not you need to send it in to have it check if the motor is still working with full power. check Mannys-Sharpening.com They can help.
Jan 28, 2011 | Andis T-Outliner Hair Trimmer
Poulan 14" electric, model# PLN1514
Hi there, a couple of features come to mind that may be the cause of your problem.
Firstly, make sure that the saw is unplugged from the power supply.
  • The chain brake is active and wont allow sprocket movement and hence the chain. If necessary, pull the front guard (in front of the front handle) back until it clicks.
  • Electric saws generally have an additional motor-stop feature built into the trigger mechanism which is deactivated when the trigger is squeezed. So, in order to move the chain along the bar the trigger needs to be squeezed releasing the motor-stop. A tip - wear gloves when handling chains and move the chain towards the bar tip ie in the direction of the cutters - if the chain suddenly stops you wont remove several layers of skin in the process ! better still use a screwdriver against the back of one of the cutters and move it forwards - there should be some resistance and there should be no slack chain on the underside of the bar. Hope this helps.
Nov 06, 2010 | Poulan 14" Chainsaw
Can not find parts
www.discountonlineparts.com
Apr 18, 2009 | Homelite 'Yard Broom' Leaf Blower
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
The blades on my Braun complete 8975 are not sharp anymore.
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
Garden Logo
276 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
