Question about Microwave Ovens
Hello, We have a sirius hood 120V 60HZ type: FSLC equip. #: SU 900 V1-A4-H2 When we try and use the fan and turn it onto 1 (lowest) then it jumps to #4 on it's own and if you try and put it back to #1 then it continuously jumps back to 4. If you then try to shut it off then it turns back on, on its own always to #4 until we have to shut the breaker Any ideas what this could be? Thanks!
5 Suggested Answers
SOURCE: microwave fan won't turn off?
hi i would think that the power problem has fried the processor
cheers grant
Posted on Oct 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: fan doesn't shut off when plugged in
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
tunde007
  • 2382 Answers
SOURCE: GE Spacesaver Microwave Oven Model
Hi, if some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
Posted on Dec 22, 2010
  • 8909 Answers
SOURCE: I have a be microwave. Turned it on to cook
Magnetron may be faulty. Have it checked by a qualified microwave engineer.
Posted on Jan 24, 2011
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
I appreciate the advice I have got. I have a step down transformer which is written 125v 15amp.Can this be used for my Daewoo DVDP480 120v 60hz 20w?
I take it that you are operating at 220volts, the step down transformer will easily run the daewoo DVD player even if the voltage is 125volts because there is allowance in the circuitry to handle more without damage and the current draw is a fraction of the demand that the the transformer is capable of delivering.
Apr 27, 2012 | Daewoo Microwave Ovens
My oster 1000 watts microwave is not getting hot
There is a semiconductor device called a triac, if food is warm the microwave is not running at full power because the triac is defective.
Apr 09, 2012 | Microwave Ovens
Model SCR 05 120V, 60Hz, 35W. Looking for a manual
Hi, can you please give more details about the manual your looking for?.. The information you gave is not enough for me to provide a manual for the product your looking for ..thanks......
Apr 08, 2011 | Microwave Ovens
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
Apr 18, 2010 | Microwave Ovens
Replacing Microwave turntable motor
if they are physically alike use it,the units are both120 volt units,you cant operate a 210 volt motor on 120 volts w/o an inverter furthermore it would be 220 volts for that type of motor,its just a production run #
Aug 25, 2009 | Microwave Ovens
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
GE Microwave vent fan replacement.
First of all, if it's just the plastic (nylon) fan blade that's melted, most any fan blade should work. I'd take the blade and motor to a local appliance parts shop and see if they have just a blade assembly that would fit. Normally the shaft diameter is standard and the only consideration is to get a blade assy whose outside diameter and thickness are the same or a little less than the original. Concerning the original part # you gave there are 3 Samsung parts that match up on http://www.samsungparts.com : Part Number Description Specification Price DE31-10178A MOTOR-VENTILATION SMV-260UA,120V,60Hz,31 $67.78 DE31-10178B MOTOR-VENTILATION SMV-260UA-1,-,-,-,-,-, $70.09 DE31-10178E MOTOR VENTILATION SMV-260UA-N,-,-,120V60 $67.87 Lastly, if there happen to be any numbers on the blade assembly itself, you can check them to see if they're good numbers at http://www.samsungparts.com Good luck!
Dec 02, 2006 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
220 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
