Question about Samsung AS1293L Air Conditioner
I plug up the unit but breaker kicks as soon as i try to put it in the outlet
  • Samsung Master
  • 43,501 Answers
There is a short in the unit...
If it is kicking the breaker as soon as you plug it in then there is a good chance that the problem is in the cord...
Anyway the best way to find the problem will be to use an OHM meter and trace down the source of the short...
heatman101
Posted on May 26, 2011
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
Reset
Jun 22, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
My refrigator/freezer is kicking off the circuit breaker each time I plug it in
Two obvious possibilites. One, it may not be the only unit on that circuit. If you have a 15 or 20 amp breaker, and have more than one unit like this, you are pulling too many amps for the breaker.That happens frequently. The other possibility is a dead short somewhere in the unit. Try plugging it in to a different outlet that you know has nothing else on that circuit. If it comes on and runs, You need to run a didicated circuit for this freezer only. A dead short in the machine will kick any outlet that it is plugged into. You will have to isolate each circuit in the freezer to find which one is grounded out.
Sep 15, 2010 | True T-23DT Bottom Freezer Refrigerator
We have arc fault breakers on our house built in 2002. in trying to plug in our 40'' lcd tv the breaker kicks out as soon as the plug touches the outlet. We've even tried brand new high end TrippLite surge...
Well, considering all TV's these days have what is called a SMPS which means Switch Mode Power Supply. As soon as your plug enters the outlet it will ark, because the power supply starts up immediately, so my suggestion would be is to kill the breaker to that room then plug the set in and then reset the breaker. Let me know how it turns out.
Oct 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
UNIT SHUTS DOWN AS SOON AS COMPRESSOR KICKS IN
Hi fdisc I feel quite sure your compressor is going straight to ground you need to get someone to check the comp, for its resistance and he or she will soon let you know for sure.
Regards
Steve.
May 24, 2009 | Danby DPAC8020 Air Conditioner
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
An old mantiwoc ice machine a bad storm hit now it does not work . plug it in as soon as contacter kicks in breaker kick off.
You have an old mantiwoc ice machine a bad storm hit now it does not work . plug it in as soon as contacter kicks in breaker kick off.
How old is it?
Any appliance that is older than 10 years old i not worth investing good money into bad.
Newer units will save you energy on your electric bill.
Bless You,
Please rate me before you leave our site.
Thank You
Sep 11, 2008 | Refrigerators
When I turn on dishwasher it kicks breaker at wall outlet.
if it is tripping the breaker you have a dead short to ground check the water inlet valve on the left side front unplug the 2 wire connector to it and plug it in see if it stays on if you you found your short if not let me know.. but i will need the model # off the unit to get the wiring diagram
Jan 21, 2008 | Kenmore 17439 Built-in Dishwasher
Samsung AS1293L Air Conditioner Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
