Question about KitchenAid Refrigerators
My ice maker stopped producing ice. help - KitchenAid Refrigerators
    Scholar:
  • 142 Answers
One quick test would be to manually put water in the ice maker and wait a few hours. If it does push the ice out, that means the ice maker is working. If it did not refill the ice maker with water the valve (in the back) may need to replaced. It is also possible that the fill tube inside the freezer is frozen. Another thing to check is the temperature in the freezer. It has to be 10 or below for the ice maker to start a cycle.
Posted on May 26, 2011
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Ice maker stopped making ice
    hi,
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
    My ice maker has stopped producing ice - I have a whrlpool fridge freezer
    Causes are:
    1. Check shut off arm- If it fails to move due to lot stored ice cubs, remove some quantity of ice cubs.
    2. Check the water pressure. Due to lack of water, it may stopped producing ice.
    3.Check freezer temp: must be around 5 degree.
    4.Check water hose has no leak. due to scarcity of water, ice maker could stop making ice cubes.
    5. If water valve defective ice cube could not be made. To check the valve please follow this step.
    Locate your ice maker, remove the ice bucket. Pull the coveroff the end of the ice maker. Locate the holes "V" and "L". Take a paper clip(jump clip) and tape. Straight the clip and put tape in middle. Hold the tapedside and insert the clip into "V" and "L". This sends the power to watervalve.If water goes into ice maker, water valve is good.Hope, is it helpful?
    Jan 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My ice maker stopped making ice...is there anything i can check myself to correct this problem
    If the ice maker has completely stopped producing ice :-
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly:-
    Check this link for your knowledge:-
    http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
    Please accept the solution if it's helpful. Do get back to us for any further query.
    Thanks for contacting fixya.com
    Sep 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Ice maker stopped working
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    jkkjffkj
    Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
    Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
    heatman101
    iot47
    Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
    Ice maker not making ice. do have water, no ice
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    Aug 29, 2009 | Kenmore Refrigerators
    LG refrigerator french door icemaker not working
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
    Ice maker won't quit dispensing ice cubes don't have ice skates!
    Dec 11, 2008 | Amana Refrigerators
    Ice maker stop making ice for kenmore 106.56352500
    Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
    Refrigerators Logo
    79 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Todd Arndt
    Todd Arndt
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
