Question about Ruud Heating & Cooling
Iwant to put freon in my unit - Ruud Heating & Cooling
  • 43,501 Answers
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on May 26, 2011
How do I replace the freon in my portable A/C unit?
you can't unless you put a saddle valve on it to hook up a hose for the gauges to put the Freon in it. If it needs Freon you have a leak somewhere. When you put the Freon in it will leak out this is why you need to find the leak.
Jul 15, 2014 | Amcor PLM-14000E Portable Air Conditioner
600 series Penquin rooftop unit
could be possibly low on freon and they are self contained units you can put a saddle valve on it and try to put freon in it. If its r22 its the high dollar freon.......have an experienced hvac guy come out.
Jul 08, 2013 | Dometic Rooftop RV Air Conditioner
Much freon c unit
There should be a sticker under the hood with the specs. If it does not have rear ac it should hold 3 or 4 cans if empty. You would use a gauge on the high side to check.
If you put too much in the high side pressure switch should cut power to the compressor clutch, but you could still damage the compressor.
Jul 04, 2013 | Ford Freestar Cars & Trucks
Put the wrong freon in a/c unit. what do i do now ? let it all out, and regas the unit or will it hurt it to leave it alone and let it run..
Reclaim and recharge. I hope you did not mix incompatible oils.
What freon did you put in verses what it should have? How much of the foreign freon is in the system (comparatively speaking)?
:o!
Jun 04, 2011 | Heating & Cooling
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
Window unit not cooling how to put in freon
You have to put a piercing valve on the sucction side because this units don't come with service port, but if you going to add freon ,it is better to fix the leak before and after that replace the drier and vacum the system.
Aug 17, 2009 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
69 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
