HI, my remote for my Tv no longer works and it has been child locked, we have bought a universal remote but it will not work. Is there a way to unlock the child lock as we need to turn down the volume on it. Thanks
  • mallory3 Aug 16, 2008
    I,big IRISH, thanks we tried it and it didnt unlock it.
  • 927 Answers
Good Day, mallory3; Try unplugging the TV from it's a/c source (reset). If this a MIT"S: To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. Good Night & luck, big IRISH.
Posted on Aug 16, 2008
  • MICHAEL MULLINS Aug 17, 2008
    Good Day, mallory3;
    It sounds like the front button assembly is defective. You can unplug it by removing the speaker and then the small panel, follow the wire harness. Then unplug. Then you should be able to use the TV via the remote.
    Give the Model Number and Brand and I'll locate part.
    Good Luck, big IRISH.
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Televison & Video
Awa lcd ltw32ds
You need the original remote control to unlock the TV.
Jan 01, 2018 | Televison & Video
My aiko tv model A3410 is on child lock and i have no remote. How do i get to child lock off?
Unfortunately, you can't disable the child lock (front panel lock) without a working remote for the TV. If you can find a universal remote that will match the Menu function of the TV, then press menu and find the child lock option. Then press Volume + or Volume - to toggle it to off.
I wish that I had better news for you. The manual for the A3410 is available here: http://ernie.awa.com.au/ArticleDocuments/1061/AIKO%20A3410%20Instruction%20manual.pdf.aspx . You will need Adobe Reader or a similar program to read the manual.
Apr 09, 2013 | Televison & Video
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Apr 23, 2009 | RCA Televison & Video
How can I remove the child lock from my TV without a remote cont
A hammer works for me. You can purchase a NEW universal remote at Walmart for as little as $5.00
Apr 10, 2009 | Televison & Video
Wharfedale lcd3210AF - remote control not working - child lock stuck on
I do know about this machine but as a general thing with electronic items :-
With the item turned off press and hold its power on button for 3 to 5 seconds before release or that in combination with either a channel change or volume button, so say power+channel up or power+channel down etc I can only hope this overides the lock out, other than that its say two buttons on a remote etc but this I do not know.
Hope this helps you.......
Jan 18, 2018 | Televison & Video
Cant get tv on
HELLO. YES IT'S TRUE ALL TV MUST BE ON TO PROGRAM THEM.!!! AND ALL MOST SET THAT HAVE A CHILD LOCK ON THEM .!!! YOU MUST HAVE THE REMOTE FOR THAT SET.!!! TO MAKE IT BRING UP THE MENU DISPLAY.!!! TO TURN ON & OFF.!!! THE CHILD LOCK..!!! THERE ARE SOME UNIVERSAL REMOTE'S THAT WILL FOR MOST .!!! TRY A (UNVERSAL CONTROL ONE) REMOTE .!!! THEY WORK WITH MOST OF THE RCA SET MADE.!!! HOPE THIS HELP'S YOU .!!! "GOOD LUCK"
Apr 30, 2008 | RCA 20F511T TV
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Feb 06, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
