Question about Refrigerators
Antares vending not cooling - how do you get to the evaporator?
4 Suggested Answers
  • 4 Answers
SOURCE: I have the same problem
You need to contact Frigidaire Parts Division. You need an evaporator for their EDINA Model FMR7. The part number is 216701200. It should cost approx. $100.00. This should be all you need. Good luck.
David
Posted on Mar 09, 2010
Testimonial: "Thank You!"
SOURCE: I have an older Antares vending machine that is
replace with new evaporator coil pn.216701200
Posted on Feb 07, 2011
domotek
  • 591 Answers
SOURCE: Antares Vending Machine Leaking water
You probably have a clogged water drain or the water pan under the machine is full of dust or dirt, look for the drain (small tube or hose usually in the back) inside or outside of the appliance, than unclog it by forcing a cleaning solution in it (water and vinegar), if the clog is too hard, you can push a small flexible wire in the tube all the way to the bottom starting from the top, or the tube is broken/cracked...
Posted on Jul 07, 2011
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Change the thermostat, that's what regulates the compressor.
Nov 28, 2013 | Refrigerators
I have an Antaris vending machine that has a frigidare cooling system. It was manufactured in 2006 and has been working fine. Recently the motor kicks on but the cooling system does not and it does not...
the antares is notorious for having evaporator problems. The evaporator is not galvanized and as such rusts after a period of time. Once rusted through the coolant is released. The machine will no longer get cold until the evaporator is replaced and the sytstem charged with coolant... gene
Aug 24, 2010 | Frigidaire Refrigerators
I have the same problem with my Antares vending machine. Do you know what the model number is on that Frigidaire freezer? I want to buy a new evaporator but can't seem to find it.
David
Mar 08, 2010 | Refrigerators
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for...
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Jun 18, 2009 | Electrolux Refrigerators
Skybox will nat cool below 40 degrees
The likely cause is a heavy frost and ice buildup on the internal evaporator plate behind the dispensing unit. Unplug the unit and open the door for 24 hours. Plug the unit back in, reset the thermostat to the 11:00 position.
Jun 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Refrigerators Logo
541 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
