Blade wont engage when i turn on toggle switch unless i strike rear pulley where switch goes into
    Sergeant:
  • 297 Answers
Assuming you are talking about a riding lawn mower, the magnetic clutch has gone bad.
Posted on May 26, 2011
Blades won't engage. I hit something, blades quit turning, check belt, its okay. When you hit button to engage blades, you hear click
When you look under the mower do you see two belts ? Top one goes to the rear axle and lower one goes to mower deck spindle.
Your description sounds like the electric clutch is engaging,so if you are seeing two belts coming off the bottom of the engine maybe the belt bounced off a idler pulley on the deck and is not tight enough.
Apr 09, 2016 | Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Rear brake lights not working
first check your fueses, if thats not it on the slinder part of the arm behind the dash "the break" arm. There is a toggel switch when you push the break the button will release causing the break lights to come on when you let off the breaks it will engage the toggle switch and turn off the break lights....if the toggle switch goes out they wont work also have some one stand behind the car and wiggle the wires of the toggle switch see if it has a bad connection before you replace the switch could be just corresion or the wires may have came loose..
Dec 22, 2010 | 1994 Geo Prizm
Engaging the blades / PTO
There is either a yellow toggle switch or a yellow knob type switch on the dash panel that will engage your deck unless some of the safety switches are stopping it from working due to an adjustment problem or a defective switch,let me know if you need more help.
Jul 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
Jun 09, 2010 | Garden
I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Have a cub zero turn 52 inch cut the blades wont engage it starts but when you pull the switch to turn on the blades it wont engage any help?
sounds like one of three possible problems ....one - there are safety switches that prevent engagement of the blades,,,,,two - the electric switch which engages the electric clutch blade pulley is bad....or three - the electric clutch blade pulley assembly is bad.....first.....make sure all ur connections are tight to the safety switches and electric clutchblade pulley.....then, if your able to read and follow a wiring diagram, get the wiring diagram for your tractor and a 12 volt probe light (with probe point end) with a ground lead....first, ground the clamp end to the frame and probe at the electric pulley clutch plug to see if power is getting there...if not...follow the wiring diagram to the next switch location the power lead comes from....if one side of the swtich shows power and the other side doesn't with the switch in the correct run position....then the switch or connection is bad.....if it probes okay...go to the next switch....follow this logic from both sides of the from the electric pulley blade clutch plug until you isolate the switch or plug problem....if everythin tested is good....then it's the electric clutch pulley assembly that need replacing.....hope this helps.....
Jun 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Replace primary belt
here you go. (should be a diagram pictured below). If no picture, then the belt routes from the engine pulley on both sides (goes around the pulley) and goes strait back in between the two smaller pulleys, one an idler, the other spring loaded tensioner. The belt goes left with one leg, right with the other (from front or back) and engages both pulleys. Then goes to both blade pulleys and around them, then "meets" each other at the rear of the deck, running  strait from one blade pulley to the other.image.tiff
Oct 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
