Question about Samsung SyncMaster 275T+ 27" Wide Format TFT screen 6 ms, VGA, DVI, HDMI, Component / YUV LCD TV
How do I connect my TV with the VCR Flat screen Samsung
  • 53 Answers
Here is the manual: http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000347&prd_mdl_cd=LS27HUBCB%2FXAA&prd_mdl_name=275T
the TV you are using has to be connected with AV devices and can only be connected to video. You need speakers if you want sound.
Posted on May 26, 2011
4 Suggested Answers
  • 11 Answers
SOURCE: VCr connection
should be a source button so kind on the remote or on the tv
Posted on Nov 24, 2007
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
  • 11 Answers
SOURCE: How to clean a Samsung flat panel TV screen?
Only with the cleaning cloth provided....
Posted on Jul 31, 2008
My Samsung TV work fine. My RcA VHS VCR when I want to record the screen said WEAK or NO SIGNAL
VCRs use Channel three or Four to watch the tape. It is better if you use the video out on the VCR to go IN to the TV video In on a modern TV.
For record, the VCR cannot see Digital TV. You must connect the Digital TV box or satellite box Video Out to the Video In on the VCR.
Feb 21, 2012 | RCA Televison & Video
A flat screen tv had to replace a tv that went out now there is no color only black and white will show from the vcr/dvd player what is the fix?
You need to set the tv for the standard set on the dvd (NTSC or PAL). If it's not helping, change the connection between the 2 devices (S-Video or RCA jack).
Mar 06, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV/vcr
VCRs are usually connected in Audio-Video inputs of TVs.
Please check what input is being used in TV for VCR cable hook up at rear of TV. Select that AV input in TV by remote and enjoy.
Oct 03, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Daewoo screen in a samsung
probably not,,,you need to look at the back of the plasma panel itself and see who really made it..the samsung is probably a samsung panel while the daewoo might be from lg..
Sep 21, 2007 | Televison & Video
Samsung SyncMaster 275T+ 27" Wide Format TFT screen  6 ms, VGA, DVI, HDMI, Component / YUV LCD TV Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
