I would like to put a lock on the router cause signal is slow with router, when not wireless it is fine, otherwise very slow.
  • 51 Answers
I assume you are talking about putting a password on your wireless router?
Type in: 192.168.1.1 in your web browser, this will take you to the router configuration page. enter the username ans password, if you haven't changed it, they will both be "administrator"
From this page select wireless security
Simply follow the on-screen instructions from there :)
Posted on May 26, 2011
My iphone 4 has become slow to connect to my Netgear DGNDv2 modem router. The connection used to be really quick but now I have to repeatedly tap the refresh button on the iphone to get it t connect.
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Mar 09, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I have tested my internet connection with my ISP and the connection is fine but the signal from my wireless router seems to be the problem. This just started out of the blue (no recent changes). Pages load...
Disconnect the router, and use an Ethernet cable to connect your computer's network-port directly to the cable-modem (or DSL-modem), and try the "performance" of Internet activity.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I do not have software for this router, but have used it for some time. It was set up by the installer of my cable/internet provider. The signal is not locked and some one is leeching off my wireless,...
First of all you don't need some kind of software to control your router, all you have to do is to connect with your browser (e.g. Internet explorer) to a specific i.p.adress. On the other way you can either change the wireless security password or passphrase or deny the wireless access at all the others computers except the 2 you mentioned. The first solution is easier but you must change the security password at your 2 computers according to the new one that you changed at the router. As you're going to change the security settings for your wireless internet, I suggest you try changing the seettings with a computer physically connected to the router, so in case of an error you will not keep out yourself.
In case of a problem, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 24, 2010 | Linksys Wireless-G Broadband Router
The wireless network is very slow compared to when I connect to one of the RJ45 ports in the back of the router. Every wireless connection I try crawls in speed. I have Wireless -G USB adapter in one...
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections.
SOLUTION:You will need to relocate your wireless router closer to your computer.
Dec 16, 2009 | Linksys WRT160N Wireless Router
Linksys WRT54G connects but is homicidally slow, and won't renew DHCP if signal falters!
Linksys wireless firmware is know for it slow connection issue. I have one and my lan speed was double then my wireless speed. I put the third pary firmware from www.dd-wrt.com website and now my wireless and lan speeds are the same.
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
The Wireless Signal keeps dropping out.
make sure that there are no cordless or wireless devices near the router such as a cordless phone since that will interfere with the wireless signal and a cause for frequent disconnection.
otherwise, the device should be replaced already.
Aug 22, 2008 | NetGear DG834G Router
Computers & Internet Logo
David Payne
David Payne
