I have this HP 6020 lights on but no display only black screen
    Sergeant:
  • 207 Answers
Try other monitor to be sure that the problem is nothing to do with your system unit. If you do and very sure that the monitor is ok, turn off and unplug the unit first and remove the video card and insert the monitor cable to its onboard location and power up the system. if your system works then the problem is surely the video card. But if not, we have a deeper problem. If you cannot hear any beeps at all when you power up your computer then the problem could be on the major components. Try removing the memory modules and reseat them back one by one to see if one of them is the culprit before powering up the system. if this works, turn off your system again and insert back the video card and the monitor cable. if these never works at all try removing all memory modules and power up the system if you never hear any beeps at all pertaining that the system memory is not present it could be that you have a corrupt BIOS program or your motherboard is defective. Clear your BIOS by finding the jumper setting on the motherboard. Usually it is labelled CLR_CMOS. The default or normal position of the jumper is 1& 2. Clear the CMOS by taking the jumper to 2 & 3 position for about 10 seconds. Be sure that your system is unplug before doing this. After 10 seconds bring back the jumper to its normal 1& 2 position then power the system on. If these works please correct the system time by going to BIOS setting. If these never work at all. Don't jump to a conclusion that your motherboard or you memory modules or your processor may be defective. The power supply unit sometimes is one of the unforeseen component that emulates this trouble. So if you have a multitester (analog or digital), set the range to 50DC and place the black lead on any black wire connections and place the red lead on any yellow wire connections. When you power up the system the multitester should read a stable 12V on your meter any drop to about 2V or intermittent reading means your PSU is defective.
Posted on May 26, 2011
I have a problem with sharp AR 6020 photocopier machine that is displaying triangle and minus symbols how can i solve it
The Triangle may be the toner low light. On the older models it would look like a Triangle of stacked up cannon balls. I am not specifically familiar with your exact model.
Feb 19, 2017 | Sharp Office Equipment & Supplies
How do i fix error 000121-000?
According to the manual which I have put here under printers and copiers "If the job or operation does not complete correctly, check the End Code, and
perform the necessary operations according to the End Code displayed. You can
check the End Code in the Details screen under Log in the System Monitor screen.
(See "Checking Job Details," on p. 2-8.)
canon imageRunner 6020 Reference Manual Reference Manual List Of Error...
Feb 01, 2015 | Canon imageRUNNER 6020 Copier
Restriction code for Nokia 6020
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
Mar 16, 2014 | Nokia Handsfree For 6020, 6101, 6102...
HP dvp6000. My screen is black. External display works fine.
Your LCD screen has back-light problem. It is caused by a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction for a possible solution :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 17, 2010 | HP Pavilion dv6000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Display is not coming , black screen is there
If you get zero display at all check if you can hook up an external monitor first to determine if problem is with screen or video card.
If display can barely be seen that is practically black but you can just see it in bright light check brightness levels of screen i cranking them up fails then you need a new screen backlight. Talk with hp about repair.
Mar 19, 2009 | HP Pavilion dv4000 Notebook
Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
Mar 10, 2009 | HP Pavillion ZV6000 Notebook
Display went from extremely dark to complely black
Hello there.
I understand that your Notebook is not showing the display lights. To isolate the issue please do the following troubleshooting steps.
1) Check the display with external monitor. If the external monitor is showing the display then the problem is with the LCD screen. If the external monitor is not showing the display then the problem is with the display card.
2) If you have any torch light or a cell phone , try focusing the light on the LCD screen after the Notebook is powered on and check whether you are able to see the texts and images on the LCD. If you are able to see the images and texts then it is the problem of the LCD back-lights. The lights which glow at the back of the LCD panel are not working.
If your Notebook is under warranty HP will repair it free of cost.
Contact HP customer chat center for more information regarding the details of the repair and the procedure for sending the Notebook to HP in case of repair.
For contacting HP chat support click on this link or copy and paste it in address bar of a web browser.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Feb 17, 2009 | HP Compaq Presario M2010US Notebook
There is NO DISPLAY on my Nokia 6020 cell phone
did you do anything to the phone.... i would suggest removing the battery for about 20 minutes and turning it back on
Dec 18, 2008 | Nokia 6020 Cellular Phone
About nokia 6020
You need to flash it by a JAF or UFS gadget. Thank you
May 26, 2008 | Nokia 6020 Cellular Phone
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
