Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
My Cub Cadet RZT 22 (85 hours) keeps blowing a fuse. It seems that I can intitially mow for approximately 20 minutes and the fuse will blow (blade stops running). I replace the fuse and it quits within 5 minutes. I have started the mower without engaging the PTO and let it run for over an hour and it's fine, so the short has something to do with the PTO. I have traced the wires, cleaned the contacts and everything looks fine. Initially, I found a bare wire very close to the plug is in the PTO clutch. Checked it and taped it up....still blowing. I'm hoping it's not the clutch itself. Expensive! Any suggestions?
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 138 Answers
SOURCE: Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Posted on Sep 07, 2009
  • 66 Answers
SOURCE: The mower deck on our Cub Cadet RZT 50 mower stopped working
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
Posted on May 31, 2010
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: Cub Cadet 1861 amp light comes on when the PTO is
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Posted on Jul 09, 2010
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a 2006 Cub Cadet RZT 42 Zero Turn Mower that keeps blowing the fuse. It would blow the fuse after long periods of use but it's gotten shorter and shorter between fuse blowing. Now it blows the fuse...
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
Nov 02, 2010 | Cub Cadet Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet zero turn mower quits mowing, service center says clutch is fine but can't find anything wrong. Put 30 amp fuses in and they will blow after about 30 minutes of mowing. Any suggestions
when the fuse blows check for hot wires it seems to have a short somewhere hardist thing to find. look for naked spots on wires or pinched wires .
Oct 21, 2009 | Garden
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
234 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
