Question about Refrigerators
Where is the water shutoff to the waterdispenser?
  • 4,066 Answers
It's either on the back in the water supply line before it connects to the fridge water inlet valve or under your sink where the water supply line comes from.
Posted on May 26, 2011
No water going to ice maker and water dispenser in the door. replaced the "dual water inlet valve" 2 weeks ago and thought the problem was solved. No problems until yesterday when the same thing start
If your water line to the refridge has a shutoff where it is connected into a house water line, this shutoff can become plugged up. A lot of them have a needle type shutoff that when screwed in shuts the water off. This is where the house line gets punctured. When screwed out this little hole can become plugged up.. Screw shutoff in and out a couple of times and if you can disconnect line from this shutoff. Then open the shutoff and see if you can get water out of it. This may allow you to flush the hole and debris out of the shutoff. Then reconnect line and see if this helps. If it happens again you may want to replace the shutoff valve with a new one.
Dec 12, 2014 | Maytag Refrigerators
Restricted waterdispenser flow on my Kenmore Coldspot refrigerator.
find the shut off valve for the water line to the refigerator.turn it closed all the way the open it up.this will clean the line. if that dont help you need to change out the water valve on the refrigerator...
Oct 22, 2013 | Kenmore Refrigerators
Bidet keeps running
If you've tried turning off both shutoffs underneath and water still runs, then the shutoffs are also likely worn out and need to be replaced. If there is no way to shut off from that point, then the only other option is to have somebody turn off all water in the house near your water meter or main water line. In many places, hardware stores will sell something called a "water shutoff key", but depending on your location, it may have a different local name.
Once water is off to the whole house, turn the hot water on somewhere in the house to reduce pressure from your water heater before replacing your faucet and shutoff valves.
It is a good idea to take one of your old water shutoffs with you to a hardware store to make sure the new one would fit propperly.
If you know somebody who can take apart the faucets to check and replace just the washers, then it could be fixed with even less expense, if you would not rather replace the faucet with a new one that will last longer.
Oct 14, 2013 | American Standard Home
Waterdispenser very slow flow
Good Afternoon, Jayslyrmn:
Look at the tap on your water faucets. If there is a mineral buildup there, white and green crusting, the same thing is happening to your water dispenser, and the ice won't taste too good either.
Check your on-board water filter. You can find a replacement here:
http://www.repairclinic.com/Kitchenaid-Refrigerator-Filter-Parts
It's literally a snap fix.
Enjoy your ice tea!
Chr
Apr 16, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Shutting off water valve problems
Some shutoff valves are pretty marginal to start with, then they corrode. They can easily break if you put too much force on the handle. You are wise to be cautious. You will have to turn of the main water supply and then replace the toilet shutoff valve. You might be able to replace the shutoff valve yourself, depending on your skills and depending on how the shutoff valve is connected to pipe coming out of the wall or floor. But keep in mind that if you get in over your head you will have no water in the house until you get that new shutoff valve in place.
If you can describe what kind of pipe that shutoff valve is connected to I can help you understand if you should tackle it yourself.
Jun 29, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Kenmore elite water dispenser works but the icemaker doesn't
It is either your water valve in the back of the fridge, the module on the icemaker.
Sep 13, 2009 | Refrigerators
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Change the water filter
Most are ok to pull as there is a shutoff in combination with feed lines... If in doubt and the water shutoff is convienient to get to turn it off. Otherwise just pull the filter...especially if it simply snaps into place as it should take care of turning off the water as the filter comes out....
Feb 15, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water shutoff
Are connections to the new valve okay. If not you have faulty new valve.
Dec 25, 2007 | Washing Machines
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
