Question about LG WM2050C Front Load Washer
Our LG WM2050CW washer has a problem with the door;it requires a lot of pressure on the door for it to lock. The door also seems to be crooked but is not loose.
  • rmcgrud1 May 31, 2011
    very helpful
  • Anonymous Mar 14, 2014
    HOW TO RESET LG WM2050CW WASHER
  • LG Master
  • 43,501 Answers
The door can be readjusted...
Just loosen the screws on the hinge side...move the door to re-alinge it and then re-tighten the screws...that should help the door to shut easier...make sure that someone did not hang on the door and spring/bend the door hinge....You may have to replace the hinge if that is the case....sometimes small children think that things like that are their own personal playground...
Door hinge
heatman101
Posted on May 26, 2011
My LG front load washer won't drain model#WM2050CW how can I fix that?
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Mar 14, 2015 | LG Washing Machines
I would like to know how do i stop the water from leaking at the bottom i have a LG WM2050CW 40 cu ft washer
wow more specific please. Sure its not leaking from the top and running down the sides inside the cover panels? If not hose leaking and or pump.
Dec 17, 2013 | LG WM2050CW 40 cu. ft. Washer
Water is coming out from the bottom
Water leaking out from the machine can be caused by a number of problems:
Check the drain pump hoses for condition and security, check the tub seals and also door seal.
There is a "CL" error
Child Lock. Look in the manual to turn it off.
Feb 03, 2018 | LG WM2050CW 40 cu. ft. Washer
We have a LG WM2050CW and today after it went the rinse cycle it drained all over the basement floor, underneath the washer and then came out of the door.
sounds like you might have a broken hose or a loose hose. remove the back panel from the unit and inspect the plumbing. also -- while you are doing the inspection - pull the pump screen/drain plug and clean out any debris that might be in there ( you will need to do this sometime anyway ).
if you are still having troubles -- please feel free to write me back here and I will do my best to walk you through it.
c...
Feb 16, 2011 | LG WM2050C Front Load Washer
I have an LG WM2050CW washer and I cannot get it to fill with water. I have checked the filters in the back and they are clean, I have checked the hoses and they are functioning. I get a buzz from the back...
Have you checked the selonoid valve? It's the piece that your hoses connect to. The part isn't that expensive when you compare it to a new machine. I changed one several years ago on a Whirlpool and I think it was around $15-20.
Nov 30, 2017 | LG WM2050CW 40 cu. ft. Washer
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Oct 12, 2009 | LG WM2277H Front Load Washer
LG WM2050C Front Load Washer Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
