Question about Jwin JV-TV1010 5.5 in. Portable Television
No function exactly mx2sb834 appear a white line in the screen
Faulty screen, horizontal lines
Battery is stuffed, replace it. White lines is the early signs or the LCD is damaged and needs to be replaced.
Jan 15, 2013 | Tomtom ONE 3rd Edition GPS
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Blue vertical line on LCD screen
Thus meaning what display on the LCD is exactly what "enters" through the lens. Is this a hairline or thick line appearing on the LCD and does the same happen on the photos/pictures when they are downloaded on a PC? If so "something" could have infiltrated into/onto the camera lens....
Jul 16, 2009 | Canon PowerShot SD890 IS Digital Camera
Ti 86
Hi I got a problem with Ti-86 which is a line of the screen pixel missing. I tried to increase and decrease the intensity of the screen (2nd and up, down). Also tried to go to MODE function. I have tried those for several times. It works great. The line of those missing screen pixel came back. I don't know why. Just try it.
Sep 12, 2007 | Texas Instruments TI-86 Calculator
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Jwin JV-TV1010 5.5 in. Portable Television Logo
158 people viewed this question
Top Jwin Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
