Can you please provide me with a Dayton Model 3AC01 High Frequency Arc Stabilizer Manual and a Dayton 230/140 amp AC/DC Welder model no. 110-114.
5 Suggested Answers
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
SOURCE: Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Posted on Feb 24, 2012
justjordy33
SOURCE: can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
Posted on Aug 02, 2012
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
Finding it hard to get the metal to pool
Simply turn up the amperage on the welder. The thicker the material, more amps are need to heat the parent metal.
However each metal is different and other factors come involved. For example, Aliumium melts at a temperature of 660 'C but has an oxide layer on the surface which melts at roughly 2100 'C. Therefore you need a T.I.G. welder with a polarity of AC HF (high frequency), to increase the hertz to deal with this high melting temperature oxide layer.
There are other factors such as sharpening the tungsten to a point if welding stainless steel/carbon steel. By doing this the arc is applyed in one direct spot rather then disposing so you can heat the metal into a pool quicker.
Make sure you have your polarity right:
DC Negative = more heat into workpiece, deeper penetration. Standard setting for steel
DC Positive = more heat into electrode, less penetration, best left for thin metal.
AC, best for non-ferrous metals, like aluminum, because the back and forth flow provides cleaning action.
Apr 16, 2011 | Welding Tools
I have a Dayton 230 amp buzz box and cann 't find a replacement fan motor anyone know where to look
Try Grainger.com/Dayton-Motor. I've had good results with grainger . Just have model number and part number if possible. They aren't the cheapest but I like dealing with them. Good luck and hope you have a good year.
Dec 30, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Lincoln electric ac/dc arc welder model ac/dc
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
Heating & Cooling Logo
205 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
